Thread: N* gains
Results 1 to 20 of 22
  1. #1 N* gains
    about to put the N* kit on a S2IC setup with a 3.1 what kind of changes/gains can I expect?
  2. #2 Re: N* gains
    Not too much actual HP/TQ gains man....BUT...throttle response and the fact you'll be pushing more air = WIN!! I think TB upgrades net under 10hp even on builds needing them...IIRC
  3. #3 Re: N* gains
    the throttle response isnt really "better"...
    the N* has a linear throttle plate movement, while our stock setup is progressive. the N* ends up being open more sooner in the pedal travel. i actually hated how it felt and went back to a hogged out stock throttle body.
    you dont need a throttle body. you need a better intake. anyone running an intercooler that isnt running an open cone is losing power.
  4. #4 Re: N* gains
    it is open cone....
  5. #5 Re: N* gains
    good job. i didnt see it in your signature so i just assumed.
    either way a bigger throttle body isnt going to help much if there is a step down from your throttle body to the blower case. did brian port that out to 75mm?
  6. #6 Re: N* gains
    yes
  7. #7 Re: N* gains
    Donating Users blowfishRus6's Avatar
    g.a.
    i thought ls1 tb was the way to go.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  8. #8 Re: N* gains
    Quote Originally Posted by blowfishRus6 View Post
    ls1 throttle body is huge. not many people need that big of a throttle body.
  9. #9 Re: N* gains
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Wait a minute, I thought the N* and the LS1 TB were the same size?
    2001 Buick Regal LS - Almost Stock
  10. #10 Re: N* gains
    a northstar is for sure 75mm...i thought an ls1 was bigger?
  11. #11 Re: N* gains
    May 2008
    staten island,NY
    i have no complaints from my N*....better throttle response and i like the LQ4 maf and 4 inch open cone better
  12. #12 Re: N* gains
    QCA, IA
    I thought it was 75mm also, but I really don't know for sure, either. Anyone know?
  13. #13 Re: N* gains
    Banned - Busted For Scamming
    Feb 2009
    stock size is 75mm but you can get ported ones that are way bigger
  14. #14 Re: N* gains
    Quote Originally Posted by QwikGT View Post
    the throttle response is not better. it is a different throttle blade opening rate. less throttle opens the blade more. i feels like better throttle response, but its just a linear blade opening. i hated how it felt. barely touch the gas and i was already boosting. id rather have to get about 1/4 into the throttle before it gets to that.
  15. #15 Re: N* gains
    Quote Originally Posted by Scimmia View Post
    Yup. 75mm. When/If I ever re-do my blower it is getting port matched to a 75mm Inlet and the LS1 is getting smoothed/polished/ported with a SLP MAF. Bish is gonna scream.
  16. #16 Re: N* gains
    g.a.
    but for the throttle response. isent that why you get a tb anyways
    its slow.
  17. #17 Re: N* gains
    I thought thats what throttle response was....
  18. #18 Re: N* gains
    No...I think this is how it goes. The N*'s blade will open at different rates due to pedal %'s vs. the LS1's blade...basically when you give the LS1 TB 50% throttle it'll really feel like 50% vs. a lag sort of feeling with the N*.
    If not, then correct me or give a better explanation, but that is how I understand it in my head.
  19. #19 Re: N* gains
    ya its sorta confusing to be honest
  20. #20 Re: N* gains
    I meant it being that if you press the pedal halfway down on a N* it won't feel as responsive with 50% throttle on a LS1'd car.
  1. Easiest HP gains
    By mikes_comp_g in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:17 AM
  2. any gains in porting the boost bypass passage?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 10:59 AM
