Thread: Filling coolant
Results 1 to 11 of 11
  1. #1 Filling coolant
    Jan 2016
    Tucson, AZ
    I drained and flushed the radiator. When I was trying to fill the radiator I could only get a little more than a gallon in. I was running the car, ac on and i has the rad cap off and the thermostat bleeder screw open. But I never got more than a couple of drops out of the bleeder screw. Over the course of a few days I’ve put close to 6 gallons in which is more than spec. It’s also overheated in traffic a couple times. I think that’s where I lost some fluid. Here’s what’s concerning - when Im filling the radiator with the car running and the rad cap off and bleeder screw open the liquid stops going down at some point and starts to “breathe” per se. After a few more minutes the liquid gets foamy or at least bubbly. So it seems like I definitely have air stuck in there but it won’t burp when I’m running the car. Also, just for completeness sake I put some Prestone sealant in with the first gallon of coolant after I flushed everything.
  2. #2 Re: Filling coolant
    6 gallons is twice what the whole system holds. check the oil to be over filled, or a leak.
    the t stat could be locked up too.
    i like to let it idle rad cap off, ac off. till it warms up and the fans come on, by that point the rad level should have burped as the t stat opened up, top off the rad again.
  3. #3 Re: Filling coolant
    Jan 2016
    Tucson, AZ
    Oil level is good and not milky like I feared.
    I’ve been following that method SD, I found your tips on other threads. I’ll leave the ac off next time My concern was the bubbles. What are your thoughts?
  4. #4 Re: Filling coolant
    I break stuff selliott's Avatar
    Kansas City
    Like Scotty said I'd check the tstat
  5. #5 Re: Filling coolant
    if you get bubbles, large burping bubbles every time you rev the engine cap off hot and full rad, you likely blew a head gasket.
    head gaskets can blow the coolant out the tail pipe too. it dont always make it to the oil pan.
  6. #6 Re: Filling coolant
    You have an air bubble.
    Pull the thermostat, it's two 10mm bolts. Lift up thermostat, fill into the intake, put tstat back on and seal it up. Fill rad and start car up. Run the car until you see it hit thermostat temp and it will go down slightly. That's how you will know it's burped of air.
  7. #7 Re: Filling coolant
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Personally, I'm lazy and like to do things easily and quickly. I like the acdelco thermostats with a small bleed hole drilled in them, then I use the lisle no spill funnel, run till hot, loosen bleeder a few times along the way and never have to refill or re- bleed.
  8. #8 Filling coolant
    Quincy, Mass
    Remember that’s a big air bubble coming out of a very small bleeder screw so for it squirt then nothing then squirt again is normal when there’s air in the system. But still check the tstat. Check the coolant elbows too make sure nothing is coming out of there. The passenger floor has coolant on it then your heater core went.
    I usually have the heat on to help get wire out of the heater core too when I’m burping.
    No more GP 04 Impala SS Indy:
  9. #9 Re: Filling coolant
    you can put the heat on but it dont matter, the heater core gets coolant year round. theres no on/off valve like the old days.
    flushing the core if you dont have heat is a option too. theres a load of trapped air.
  10. #10 Re: Filling coolant
    I have the lisle funnel and ... once in a while a motor will fight you to burp it.
    pull the stat.
  11. #11 Re: Filling coolant
    May 2008
    Schuyler, NE
    I've had a few fight me as well. Jacking up the front end can help.
  1. Filling the pocket on a gen 5 SC
    By Macksauce in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2017, 11:53 PM
  2. having filling troubles
    By TEK310 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2012, 10:19 PM
  3. Filling Up takes 20 minutes...
    By White Cerebus in forum General Tech Discussion
    Last Post: 08-01-2011, 04:37 PM
  4. Proper Coolant Filling Procedure?
    By TronCarter in forum General Tech Discussion
    Last Post: 04-20-2010, 07:11 PM
  5. Fuel Leak While Filling Up
    By jshifti33 in forum General Tech Discussion
    Last Post: 04-05-2010, 08:44 AM
