Thread: SC snout removal
Results 1 to 20 of 39
  1. #1 SC snout removal
    GT Level Member Jaredthefail's Avatar
    Nov 2015
    Olive branch, MS
    Alright, I know there are a lot of things about this out there, but my sc about is really stuck on there and I don't understand a few things.
    Where can I hit with my rubber mallet? I'm kind of scared to hit towards the end or the pulley.
    What can fit in the holes for prying it apart and not damage it?
    Here is where I am
    And I read somewhere that there is a way to do this without taking the alternator off but I can't get this bolt out.
    It is loose all the way though
    There is now a space that is almost big enough for a box cutter blade
  2. #2 Re: SC snout removal
    Buffalo
    Whack it anywhere with the rubber mallet to break the seal - you can't hurt it unless you're Thor
  3. #3 Re: SC snout removal
    I smack right on the pulley with a mallet.
  4. #4 Re: SC snout removal
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I used James's method. Stick the square end of a 1/2" extension in the squares and fit something like a prybar in the remaning gap. I actually used a 1/4" extension instead of a pry bar, and twist. It will force it open. Worked like a charm for me.
  5. #5 Re: SC snout removal
    GTP Level Member buickman104's Avatar
    NYC
    If it is putting up that much of a fight, make sure that you didn't miss a bolt.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  6. #6 Re: SC snout removal
    Nov 2015
    Olive branch, MS
    I like the prying idea. That's what I'll try now.
  7. #7 Re: SC snout removal
    Nov 2015
    Olive branch, MS
    Quote Originally Posted by buickman104 View Post
    That was one reason I put the pictures. I got all the bolts that you can see and I can't find any more. I even got the one that goes into the intake manifold
  8. #8 Re: SC snout removal
    Kemmerer, Wyoming
    there is a bolt on the very bottom that you might have missed
  9. #9 Re: SC snout removal
    The snout has 9 bolts that run into the case itself, then the 1 into the LIM.
  10. #10 Re: SC snout removal
    Kemmerer, Wyoming
    this is the bolt I was talking about
    http://i1115.photobucket.com/albums/...ps7letaana.jpg
  11. #11 Re: SC snout removal
    Nov 2015
    Olive branch, MS
    Sh!t.................. I had no idea that one existed.
    I have 8
  12. #12 Re: SC snout removal
    Nov 2015
    Olive branch, MS
    I got it now and the coupler too
  13. #13 Re: SC snout removal
    Nov 2015
    Olive branch, MS
    New coupler
  14. #14 Re: SC snout removal
    Nov 2015
    Olive branch, MS
    Now how much anaerobic gasket maker do I need?
    Do I put it on both sides?
  15. #15 Re: SC snout removal
    Just stick it on the snout and bolt it on.
    A thin layer is all you need, it will get spread out as you bolt it down.
  16. #16 Re: SC snout removal
    Nov 2015
    Olive branch, MS
    Awesome. Everything is back together and I'm going to let it sit and dry before I fill it with oil. Probably tomorrow morning
  17. #17 Re: SC snout removal
    Eh, I fill them right away and just drive it.
    They really only need a little set time, the heat will cure it faster lol.
  18. #18 Re: SC snout removal
    NYC
    Ask me how I had a feeling you missed one. ��
    I missed one too. ��
  19. #19 Re: SC snout removal
    Nov 2015
    Olive branch, MS
    Well I'm done for the night now. Tomorrow I will just fill it up and check for leaks. Let's just hope there's nothing else I missed
  20. #20 Re: SC snout removal
    Apr 2015
    I put mine on the case and then slid the snout. But my supercharger isn't on my car so it was easier. Doesn't matter, just as long as you don't put a huge amount of it to the point where it gets all over the drive gears in there.
  1. GEN V - LIM - N* Kit - MPS - GEN III Snout
    By trewyn15 in forum For Sale - Parts
    Last Post: 11-02-2013, 08:46 PM
  2. Need a Gen V Snout...
    By rodguezsciii in forum Wanted To Buy - Parts
    Last Post: 03-16-2013, 06:18 PM
  3. Pig Snout
    By TheNoob23 in forum Off Topic Discussion
    Last Post: 11-28-2012, 03:24 PM
