Thread: 1/4 mile guesstimate for my gtp?
Results 1 to 13 of 13
  1. #1 1/4 mile guesstimate for my gtp?
    Mar 2016
    Toledo oh.
    I have a 2002 4 door gtp with 130k miles on it. It has cai, U bend delete, 180 thermostat, and i am getting a zzp tune. Do u guys think it will go 14.20's with these mods? Or do I have too high of expectations. Thanks
  2. #2 Re: 1/4 mile guesstimate for my gtp?
    so its stock? 15 flat, or high 14's. zzp tune is not a real mod. some times they make things worse. neither is a u bend delete 180 t stat or a open cone filter.
  3. #3 Re: 1/4 mile guesstimate for my gtp?
    Mar 2016
    Toledo oh.
    Lol ok. So I guess it will go slower than stock?
  4. #4 Re: 1/4 mile guesstimate for my gtp?
    its as fast as stock, hair better, unless you got kr like all zzp tunes offer lol kr makes it slow due to it pulling timing.
    theres lots of factors involved, driver for one, same car your friend may run faster then you. or slower.
  5. #5 Re: 1/4 mile guesstimate for my gtp?
    Mar 2016
    Toledo oh.
    Understood, I've been drag racing for 15 years. I was under the assumption these cars went 14.50's stock. And figured I'd be able to knock 2-3 tenths of pretty easily (which isn't alot to ask in the 14 second range.) I have a trans am that would take about another 40 horse to knock 2 tenths off but it's a different level.
    So knowing I have a 15 second flat car, I guess my new goal is to go 14.50-14.60. I'm confident I'll be able to 60 foot it for whatever it's worth as far as that goes
  6. #6 Re: 1/4 mile guesstimate for my gtp?
    with all the mods in my sig, id be happy with a 14 or high 13 even. im not a drag racer really, but it takes some mods to make faster times.
    stock cars tend to trap around 96 mph, modded 106 ish and up of course from time slips ive seen. we got a whole section on that iirc.
  7. #7 Re: 1/4 mile guesstimate for my gtp?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    stock pulley and a 2.1x short time should be good for a 14.6 - 14.8 in the 1/4 mile. cut the 60' time to a 2.0x and you'll have a 14.5
    drop to a 3.4 pulley and knock down to consistent 14.0 - 14.2's
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  8. #8 Re: 1/4 mile guesstimate for my gtp?
    Mar 2016
    Toledo oh.
    Ok well I apreciate your input and info.
    I guess I'm prolly overly optimistic (like 99% of the people I know lol). My t/a responded very well to basic mods so I assumed the same for this car. The stock e.t. is a little slower than I expected to begin with but a trap speed in the mid 90'S isn't too bad imo.
  9. #9 Re: 1/4 mile guesstimate for my gtp?
    Buffalo NY
    here's a list of my GTP's times with the mod list and conditions for each run
    https://web.archive.org/web/20050206...zo/racing.html
    I did install a SSIC and improve the PB to 13.89 @ 101 but I don't have that run in the table
  10. #10 Re: 1/4 mile guesstimate for my gtp?
    Race fuel will help.
  11. #11 Re: 1/4 mile guesstimate for my gtp?
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    my 2 dr 98 at norwalk ran 14.20's with nothing but a CAI and a good tuneup with a 2.0 60'
  12. #12 Re: 1/4 mile guesstimate for my gtp?
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    I did 14.6 with a DP, catback and cone intake. With the Methanol, I'm hoping for a high 13
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  13. #13 Re: 1/4 mile guesstimate for my gtp?
    Jun 2012
    Cold Spring, MN
    My old 1999 SSEi:
    Intense 3.5" FWI
    180* t-stat
    ZZP 1.0
    Ported and ceramic coated front manifold
    3" mandrel bent dp
    3" mandrel bent cat to where y-pipe is on GTP
    Borla 3" inlet/dual 2.5" outlet muffler
    3.5" pulley
    2 gallons 104 octane/~5 gallons 91 pump gas
    removed spare tire, floor mats, jack
    ELC tricked (Bonneville rear air struts pumped up..... makes it slightly better than non-worn out w-body stock rear suspension)
    ZZP UD WP pulley
    Autolite 605 or 104 (I forget which one) plugs gapped @ .055"
    Rear tires aired up to 50 psi
    Worn out Hoosier QTP's at ~20-22 psi
    60' 2.17
    1/4 13.87 @ 99 mph
  1. 9x, xxx mile L67
    By retic in forum For Sale - Parts
    Last Post: 07-31-2014, 10:55 AM
  2. 9x, xxx mile L67
    By retic in forum Wanted To Buy - Parts
    Last Post: 07-13-2014, 10:00 PM
  3. 1/4 Mile
    By zildjian102 in forum Off Topic Discussion
    Last Post: 04-16-2011, 07:43 AM
  4. 77k mile l67 ???
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2010, 07:03 PM
  5. What do you think I will run in the 1/4 mile?
    By jmj4492 in forum Off Topic Discussion
    Last Post: 04-22-2010, 05:43 PM
