Thread: Methanol install
Results 1 to 15 of 15
  1. #1 Methanol install
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    Has anyone ever installed the tank and pump in the trunk of the car? And fed the line up to the engine bay? There is absolutely no room for the tank and pump in the bay so I'm brainstorming other ideas. Any suggestions?
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  2. #2 Re: Methanol install
    im sure it has, have you tried looking in the front bumper? i got my ic res tank mounted up there.
  3. #3 Re: Methanol install
    Jan 2014
    AR
    GPs don't have any space to speak of there either. The biggest empty void nearby is ahead of the driver's front wheel, behind the bumper. Where the filter on a CAI setup sits, or near there.
  4. #4 Re: Methanol install
    if you take that plastic cover off i bet you find space in the front. my car came with some rubber flap crap over that area, it was removed 5 years ago.
    you need to be able to refill his meth tank too, so lower side of the bumper wont cut it.
    and most meth tanks are kinda small looking to me. smaller then the tank i got i think. mines like 6 tall 6 wide, 4 deep.
  5. #5 Re: Methanol install
    Jan 2014
    AR
    Maybe the right tank shape would fit up there then. GPs do have some extra ductwork in the way behind the tiny grilles. If he has a CAI already, theres some room over by the tower. Surely this has come up in previous threads and been neatly solved. In the hot rod shop, you start with a sheet of aluminum and just make it to fit the available space lol. A creative person might also look to the cowl area.
  6. #6 Re: Methanol install
    ive seen tanks on the firewall too. pass side may have room.
  7. #7 Re: Methanol install
    You can also move your battery to the trunk and free up that space to mount a tank
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  8. #8 Re: Methanol install
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    i ditched the Onstar module in the trunk, mounted the pump there, and the 5qt tank behind that on the trunk wall. works great!
  9. #9 Re: Methanol install
    Feb 2014
    Rhode Island
    I have a cone intake but I put the PCM tray there so there is a bit of room but a tried to put it in and there isn't enough room. I thought of the firewall but it's a bit out of the way to fill. Is the trunk not a good idea? I was gonna put pump and tank in the trunk, run a line under the car and come up with fuel lines for the nozzle
  10. #10 Re: Methanol install
    Kemmerer, Wyoming
    I was planning on using the windshield wiper fluid reservoir for methanol/water storage because it holds a lot, and when it get's low you get a message to refill it. and also nothing wrong with spraying the water methanol combo on your windshield to clean it.
  11. #11 Re: Methanol install
    Feb 2014
    Rhode Island
    I would consider that but I cannot get the pump to fit anywhere on the front side of the engine bay lol
  12. #12 Re: Methanol install
    Feb 2014
    Rhode Island
    Quote Originally Posted by danomite02 View Post
    Did you drill a hole in truck to run the tubing?
  13. #13 Re: Methanol install
    Feb 2014
    Rhode Island
    Also what nozzle do I use? I have 2 in the box, a 375ml/min and a 625ml/min. It says the 375ml nozzle is for 350whp but you can lower injection amount my lowering pump pressure. What's my ideal setup you think?
  14. #14 Re: Methanol install
    Jul 2016
    Ft. Worth, Tx
    What kind of timing/size pulleys are you guys running with tha meth on pump gas?
  15. #15 Re: Methanol install
    How do you wish to use the meth?
    Do you want to use to combat the knock or as an extra fuel source??
    That will kind of determine how far you can take it. Say you were running 93 pump gas and a 3.2 pulley and you were running out of injector, you could use the meth to basically add fuel and cool the temps down. Then you might get away with another 1-2º of timing. Figure on any small pulley if you can get away with 14-16º of timing you are doing pretty good, some cars may only like 12-13º. This was a bad crude example but sort of how it works.
    I don't see the need for meth injections unless you plan to run down around a 3.0-3.2 pulley range because that point the supercharger is creating a ton of heat compressing that air and regular pump gas burns pretty hot and could create alot of knock.
  1. E85 or Methanol
    By SgtMarshal in forum Off Topic Discussion
    Last Post: 06-04-2015, 10:31 AM
  2. wtb methanol kit
    By jrb1027 in forum Wanted To Buy - Parts
    Last Post: 08-01-2013, 09:10 PM
  3. water methanol
    By josbourn1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2012, 09:34 PM
  4. Methanol Injection ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-01-2010, 08:28 PM
