Thread: Just got car now knocking
Page 1 of 12 12311 ... LastLast
Results 1 to 20 of 237
  1. #1 Just got car now knocking
    Mar 2016
    Monroe louisiana
    2005 gtp 132k miles. Got the car with a miss on cylinder two. Turns out maybe someone pulled spark plug wire out back there. I plugged it back in. It ran better , but it broke up at wot. So I changed spark plugs and wires. Acdelco. Car now has full power and not missing anymore. Drive ten miles now rattling under the hood. Sounds bad. I got the car at an auction. I'm thinking now someone pulled number two wire to mask the problem. Car is in great shape. Interior perfect. Could it be the supercharger or can I really have Rod knock at 132k?
    https://youtu.be/zNZ8WCGYFCI
  2. #2 Re: Just got car now knocking
    that dont sound good at all. sounds like the bottom end.
  3. #3 Re: Just got car now knocking
    Yuuuup motor swap time
    Sent from my KYOCERA-C6745 using Tapatalk
    04 Comp G.
  4. #4 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Quote Originally Posted by REDCRAPGP View Post
    Also smoke was coming out of dips tick tube when I took it out while running. I put regular gas in it then premium. Still no hope? Lol
  5. #5 Re: Just got car now knocking
    That's how mine sounded
    So hopefully you didn't spend to much on it
    04 Comp G.
  6. #6 Re: Just got car now knocking
    GTP Level Member
    Oct 2014
    Time for 10w40
  7. #7 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
  8. #8 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Guess I'll drive it till a rod slings out of the block. Can I use a non supercharged engine? This is my first front wheel drive vehicle. I own a 99 trans am and 06 envoy denali. Wish I would've bought something else to pay around with now
  9. #9 Re: Just got car now knocking
    For a direct drop in without any other mods needed, you need a low compression L67 or L32 block.
  10. #10 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Yea it's done. I just cranked it back up. The belt squeaked and it shut off by itself. It's done lol. Previous owner must have driven the piss out of it. I should've listened to my friend. He told me not to touch it.
  11. #11 Re: Just got car now knocking
    Fixing what you did had really nothing to do with it spinning a bearing.
    It's a common failure among theses motor, lack of care or moisture in the oil will kill them. Water or coolant is bad news.
  12. #12 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Oil was fresh. I'm thinking lack of care from previous owner. I knew something was up with a low mileage gtp at an auction. I'll have to find another car to flip at the auction this week. Have to get this one up and running asap. So I would have no problem using an engine from an 2008 grand prix without supercharger option. Just swap my top end on it?
  13. #13 Re: Just got car now knocking
    Swap the top half of it and have someone adjust the tune of the pcm, are you planning on flipping this or driving it? If your driving it your gonna want some flow mods.. At a minimal headers
    04 Comp G.
  14. #14 Re: Just got car now knocking
    You couldn't do to it without having to add mods like headers and a tune for sure.
    The NA 3800 is a 9.4:1 compression ratio compared to the 8.5:1 on the supercharged cars. Higher compression with boost must have more exhaust flow and atleast a good tune to prevent it from killing itself.
  15. #15 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    Oh ok. I'll try to locate a supercharged engine then. Do the supercharged engine have problems with lower intake gaskets leaking into cylinders?
  16. #16 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    If I spend over a thousand I'm keeping the car. I was trying to flip it
  17. #17 Re: Just got car now knocking
    Basically all 95-05 motor have plastic intake gaskets that are prone to leaking at some point.
    05.5+ motors switched to aluminum intake gaskets.
  18. #18 Re: Just got car now knocking
    Enfield, CT
    06.5 model year is when they started the aluminum gaskets.
  19. #19 Re: Just got car now knocking
    I'll agree to disagree there. Technically 06 was the start but many motors were already built in 05 and sure some early 06's built in 2005 got them.
  20. #20 Re: Just got car now knocking
    Mar 2016
    Monroe louisiana
    I'll remove the spark plugs and see before I order another engine. I'll keep you guys updated
  1. knocking
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2012, 01:34 AM
  2. Knocking
    By gtpzmdc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2012, 11:30 PM
  3. 99 GTP Knocking
    By BoNeZ in forum General Tech Discussion
    Last Post: 10-28-2010, 05:52 PM
  4. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  5. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
