Thread: Relentless P0300 code
Results 1 to 19 of 19
  1. #1 Relentless P0300 code
    SE Level Member gofast's Avatar
    Mar 2016
    Hope someone can help. 2004 Monte Carlo SS supercharged. Rough idle, runs perfect from off idle to any rpm as long as it's not boosting. When it gets to boost it goes right back to its random misfiring. And sometimes shows a too rich code but only if it tries to boost for more than a couple seconds. It has a new cat, resonator, MAF, IAC, PCV, ICM, plugs and wires, and has updated PCM from the dealership today and still has the same problem. New head gaskets and intake gaskets less than a yr ago. Could it be a bad intake gasket or a warped lower intake manifold?
    Sent from my SM-G900R4 using Tapatalk
  2. #2 Re: Relentless P0300 code
    Done a compression test yet??
    And what brand of plugs??
  3. #3 Re: Relentless P0300 code
    Mar 2016
    No compression test yet because it runs great without boost. Don't know brand of plugs, just bought it with this problem and was told he tried new plugs and wires and they do look brand new. Wires are actually Delco so I'm assuming the plugs are too.
  4. #4 Re: Relentless P0300 code
    Mar 2016
    Wire are AC Delco. All the other stuff is the new stuff I have done to it.
  5. #5 Re: Relentless P0300 code
    pull a plug read the # on it, google it, see if its a platinum plug, if it is buy iridium plugs.
  6. #6 Re: Relentless P0300 code
    Mar 2016
    I will do that but would that cause the rough idle and rough under boost?
  7. #7 Re: Relentless P0300 code
    Mar 2016
    And also it has a new EGR valve too.
  8. #8 Re: Relentless P0300 code
    Quote Originally Posted by gofast View Post
    they cause misfires. your engine hate that kind of plug. if you didnt install them, see whats in there.
  9. #9 Re: Relentless P0300 code
    Mar 2016
    I will look. I was told the car ran great till it just started doin that one day and he put new plugs and wires on it and it still does the same thing.
  10. #10 Re: Relentless P0300 code
    icm could be bad too. the part under the coils.
  11. #11 Re: Relentless P0300 code
    Mar 2016
    Already replaced that new too.
  12. #12 Re: Relentless P0300 code
    GTP Level Member buickman104's Avatar
    NYC
    I had that exact same issue. Turned out to be a crank sensor.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  13. #13 Re: Relentless P0300 code
    hangover park IL
    i had one with a wiped exhaust lobe cause this issue, then a few hundred miles later it was a hard mis as the cam lobe and lifter ceased to exist
    ~James~ Psychotic Gearhead
  14. #14 Re: Relentless P0300 code
    Mar 2016
    I hope that's not the problem. It runs strong and smooth as long as it's not idling or boosting.
  15. #15 Re: Relentless P0300 code
    Mar 2016
    Found the problem, cracked head between #4 & #6 cylinders.
  16. #16 Re: Relentless P0300 code
    GXP Level Member
    Mar 2015
    Tomball
    Cracked where and how did you end up figuring that out?
  17. #17 Re: Relentless P0300 code
    Mar 2016
    The machine shop just said it was cracked between the #4 & #6 cylinders. I haven't seen it yet.
  18. #18 Re: Relentless P0300 code
    NYC
    Don't most of these heads have cracks and run perfectly fine like that?
  19. #19 Re: Relentless P0300 code
    GXP Level Member
    Mar 2015
    Tomball
    Not between cylinders, that's usually between the valves. I would be interested in seeing what happened.
    Jeff
  1. P0300 code , need help !!
    By damohr in forum General Tech Discussion
    Last Post: 03-04-2015, 07:44 PM
  2. someone help? p0300 code
    By ericg1181 in forum General Tech Discussion
    Last Post: 04-07-2014, 02:09 PM
  3. 4-5k rpm misfire, Code P0300.
    By trailshredder in forum Engine
    Last Post: 11-13-2011, 07:43 PM
  4. Sputtering and P0300 code
    By grngt97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 02:12 PM
  5. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
