Thread: Starting problems
Results 1 to 11 of 11
  1. #1 Starting problems
    SE Level Member r3dr4ng3r95's Avatar
    Jan 2016
    Sometimes when I fill up on gas (92) my 02 gtp won't start. It'll turn over and die and just keep turning over for about 30 seconds. I have to push on the gas as I'm starting to stay stable. Any ideas as to what causes this?
    Sent from my HTCD100LVWPP using Tapatalk
  2. #2 Re: Starting problems
    in need a tune up super bad, or the tb could be absolutely filthy and need to be cleaned.
    and only after you fill the tank? the check engine light on?
  3. #3 Re: Starting problems
    Jan 2016
    Service engine soon comes and goes for the last 2 months. Throwing up thermostat code.
  4. #4 Re: Starting problems
    Jan 2016
    But Yea it's happened 3 times now and each time was after a fill up
  5. #5 Re: Starting problems
    Jan 2016
    I went and bought some maf cleaner and tb cleaner today so hopefully I get around to it the next couple days. Only thing is doesn't the tb need to be torqued to spec? Or not that big of a deal?
  6. #6 Re: Starting problems
    Jan 2016
    Also got a 180 tstat to hopefully get rid of the code coming and going but unsure as to what coolant to get to replace what's in it. (Orange Dex cool) been reading around and dunno if I should switch to the green stuff or stick with what's in there.
  7. #7 Re: Starting problems
    t stat has nothing to do with this.
  8. #8 Re: Starting problems
    Jan 2016
    That's the only code that pops up. P0128
  9. #9 Re: Starting problems
    Jan 2016
    Possible fuel pump failure?
  10. #10 Re: Starting problems
    see if you got pressure at the rail. turn key to run, push the pin in under the black cap on the rail.
  11. #11 Re: Starting problems
    SE Level Member snaggs5899's Avatar
    Feb 2016
    Iac. Mine was doing that also my 2000, changed the bias and it starts and runs like a champ.
    Sent from my SM-N910V using Tapatalk
  1. Starting problems
    By SCGTP in forum General Tech Discussion
    Last Post: 06-19-2011, 10:18 AM
  2. Starting Problems
    By ksp72465 in forum Introductions/Noob Questions
    Last Post: 03-14-2010, 11:52 PM
  3. Starting problems.... please help
    By gtmgooser in forum General Tech Discussion
    Last Post: 12-23-2009, 10:22 PM
  4. Just starting; problems already!
    By Merlynn in forum Introductions/Noob Questions
    Last Post: 09-12-2009, 09:23 PM
  5. starting problems
    By redgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-16-2008, 12:24 AM
