Thread: Upper Intake Gasket GTP
Results 1 to 9 of 9
  1. #1 Upper Intake Gasket GTP
    Feb 2016
    Alabama
    Where can I buy an upper intake gasket for 98 GTP? How do you take the supercharger off the motor to get top half off the motor?
  2. #2 Re: Upper Intake Gasket GTP
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    It's called RockAuto, Advance Auto Parts, NAPA, etc. Every auto parts store has them. There are several write-ups on here telling how to remove the S/C.
  3. #3 Re: Upper Intake Gasket GTP
    gasket is called a upper plenum gasket, any parts store should have it for like 12 bucks.
    unplug the injectors and sensors on the tb and the two vac lines off the top, then take 4 little nuts off the fuel rail, then pop the rail and injectors out, take belt off, then the tb cables, then un bolt it. and take it off.
  4. #4 Re: Upper Intake Gasket GTP
    Feb 2016
    Alabama
    Wasn't sure just thought I'd make sure.
  5. #5 Re: Upper Intake Gasket GTP
    this vid covers a lim job.
  6. #6 Re: Upper Intake Gasket GTP
    Yup; and never buy the Garlock gasket.
    Felpro or nothing.
    Also; metal/aluminum gaskets for the lower intake.
  7. #7 Re: Upper Intake Gasket GTP
    Feb 2016
    Alabama
    Yeah I just had to purchase the upper intake gasket for my own 01 gt and my dad has been a mechanic for 20 years and said the same, Fel-pro is the best in his opinion. We just were unsure as he had never worked on a gtp and was lost as to everything since the supercharger is on there and so on. Thanks for the advice guys!
  8. #8 Re: Upper Intake Gasket GTP
    sc is just a intake, once its unbolted its old school nuts and bolts.
  9. #9 Re: Upper Intake Gasket GTP
    Buffalo
    A greasy set of Legos
  1. Advice on Which Upper Intake Gasket do I need?
    By 94GrandPrixSE in forum General Tech Discussion
    Last Post: 08-22-2014, 02:51 PM
  2. Upper intake gasket
    By jewell83 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2014, 02:02 PM
  3. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  4. So I replaced upper intake manifold gasket
    By jmn in forum Introductions/Noob Questions
    Last Post: 11-07-2013, 08:50 AM
