Thread: Valve Lash
Results 1 to 4 of 4
  1. #1 Valve Lash
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    Do you have to set the valve lash when installing roller rockers?
  2. #2 Re: Valve Lash
    SE Level Member lageR's Avatar
    Jan 2009
    IL
    There is no lash adjustment on a hydraulic lifter engine like the 3800
    You can crudely estimate lifter preload by counting rocker bolt turns, but that's about it.
    Torque them down and go!
  3. #3 Re: Valve Lash
    Wichita, KS
    Unless your running the OE-R lifters by Comp Cams, its install and go.
    If your running those lifters, you need to run adjustable rockers, then you get to adjust last.
    Or...running a thinner head gaskets, with machined heads, and a decked block...you end up with little longer push rods, so adjustable roller rockers come into play again.
    ~F~
  4. #4 Re: Valve Lash
    Jan 2009
    ny
    Thanks
  1. EGR valve
    By cobra8432 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2011, 11:12 PM
  2. valve lash.
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2009, 08:43 AM
  3. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
  4. EGR Valve?
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:24 PM
  5. Location of PVC Valve
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2008, 08:49 AM
