Thread: Fuel injectors?
Results 1 to 20 of 24
  1. #1 Fuel injectors?
    Oct 2015
    Qulin Missouri
    I have a 06 gp gt and it has 38 pound injectors i got it tuned and he said it needs 42 pound inectors as they went to 110%.He said to get more power get bigger injectors. Where an i find these? Iv'e looked everywhere!
  2. #2 Re: Fuel injectors?
    eBay, ZZP, I think Intense.
  3. #3 Re: Fuel injectors?
    Kemmerer, Wyoming
    google search "ev6 42 lb injector"
    also
    http://www.getoverkilled.ca/3800sc.html
  4. #4 Re: Fuel injectors?
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    my 42#'s are green tops from ford lightning.
  5. #5 Re: Fuel injectors?
    Sep 2014
    Worcester, MA
    You're at 110% and he only told you to increase injector size by 10%? Ideally you want 85% duty cycle maximum, so maybe more like a 48# injector is appropriate.
  6. #6 Re: Fuel injectors?
    Wait.. What's all done to this car that your needing bigger injectors
    04 Comp G.
  7. #7 Re: Fuel injectors?
    May 2008
    Schuyler, NE
    It's an 04+ car...it's not actually at 110%.
  8. #8 Re: Fuel injectors?
    Oct 2015
    Qulin Missouri
    Just a tune with a laptop he adjusted fuel timing shut down and how much boost the super charger is putting out. the supercharger is putting out 10 psi it was dumping boost but he eliminated that also. It will do 140 with ease.
  9. #9 Re: Fuel injectors?
    So it's a stock car w/ just a tune?
    If so I seriously doubt that your putting out 10 lbs of boost and that's your outflowing your injectors.
    04 Comp G.
  10. #10 Re: Fuel injectors?
    Oct 2015
    Qulin Missouri
    His laptop was showing that
  11. #11 Re: Fuel injectors?
    how about a mod list. is it stock or not? is it tuned or not? cause very few can tune a 06 up.
  12. #12 Re: Fuel injectors?
    Oct 2015
    Qulin Missouri
    Everything is stock it is tuned is all
  13. #13 Re: Fuel injectors?
    Kemmerer, Wyoming
    Quote Originally Posted by Grand prix 06 View Post
    I'm curious how the supercharger dumps boost, and also how the supercharger can make more boost without changing pulleys.
  14. #14 Re: Fuel injectors?
    your being lied to, sorry. sounds like your at a shop of some sort.. whats this person using for a tuner?
    stock pulley will never out flow the injectors. they dont get maxed out till you have a 3.2 pulley. and you cant tune for more boost. it just dont work like that.
  15. #15 Re: Fuel injectors?
    Quote Originally Posted by ScottyDoggs View Post
    Bingo
    04 Comp G.
  16. #16 Re: Fuel injectors?
  17. #17 Fuel injectors?
    Yup find someone else to tune it, the guys full of sh*t you don't control the amount of boost the SC puts out, that's done with flow mods and smaller pulleys and there is once again no way in hell your outflowing those stock injectors on a stock setup.
    04 Comp G.
  18. #18 Re: Fuel injectors?
    Quote Originally Posted by REDCRAPGP View Post
    Yup find someone else to tune it, the guys full of sh*t you don't control the amount of boost the SC puts out, that's done with flow mods and smaller pillows and there is once again no way in hell your outflowing those stock injectors on a stock setup.
    Smaller pillows?
  19. #19 Re: Fuel injectors?
    Fcuk autocorrect lol
    04 Comp G.
  20. #20 Re: Fuel injectors?
    GXP Level Member
    Mar 2015
    Tomball
    Just a tune with a laptop. He adjusted fuel, timing, fan shut down and how much boost the super charger is putting out. the supercharger is putting out 10 psi it was dumping boost but he eliminated that also. It will do 140 with ease.
    Fixed that for you.....
    My 05 is stock and makes just a little over 10 psi and there are settings within DHP that can limit boost via traction control. It sounds like the OP either doesn't have a grasp of the English language or is lazy and can't form a complete sentence. It also sounds as though he is only repeating what he was told and he doesn't know exactly what the guy was talking about.
    * Torque management not traction control
    Jeff
  1. WTB: fuel line from injectors to fuel filter for 99GTP coupe
    By Swole in forum Wanted To Buy - Parts
    Last Post: 08-25-2014, 02:36 PM
  2. WTB: L67 Engine Harness, Computer, Fuel Rails and Fuel Injectors
    By trailtoy83 in forum Wanted To Buy - Parts
    Last Post: 03-07-2013, 03:10 PM
