Thread: Series 3 to series 2
Results 1 to 9 of 9
  1. #1 Series 3 to series 2
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    I found a 04 grand prix with a 3.8 na that dosent run,my 98 is gonna cost well over 650 bucks to get it nice,the 04 is only 650 bucks,what do I need to do to put my 98 3.8 sc engine and trans in it?
  2. #2 Re: Series 3 to series 2
    tranny wont work, but you can install the engine, then get a gen 3 to 5 tb adapter plate and a tuned pcm for the engine swap.
  3. #3 Re: Series 3 to series 2
    Jul 2010
    So the pcm out of my 98 won't work? So regardless my trans won't work period? Can't I use the na trans and use the 3.8 torque converter?
  4. #4 Re: Series 3 to series 2
    its the hook up of cables and plugs, and the way the tranny works in a 04. you would swap the flex plate so the engine fits the na tranny's converter.
    the pcm is not he same at all. dont even look the same, nor are the plugs to it the same. 04 up has 3 plugs.
  5. #5 Re: Series 3 to series 2
    Jul 2010
    Oh ok thanks,I'll probably try to find a series 3 and trans sc and put it in if I can't get it started
  6. #6 Re: Series 3 to series 2
    Jul 2010
    the fuel pump comes on,battery is good,throws code p0036 and will not start but turns over, has fuel pressure,what can it be? ive replaced fuses and relays
  7. #7 Re: Series 3 to series 2
    Quote Originally Posted by 94grandprix View Post
    Do you have spark?
  8. #8 Re: Series 3 to series 2
    Jul 2010
    Quote Originally Posted by Slick2500 View Post
    Do you have spark?
    Honestly didn't think to check but I'm gonna back over there to it soon and gonna check and put more coil packs on it
  9. #9 Re: Series 3 to series 2
    Jul 2010
    Forgot to mention it runs great or did and I started driving and made it 15 miles and it died like motor wise I still had power
  1. Series III heads on series II motor
    By Dadkota in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2015, 03:59 PM
  2. How to tell the difference between a 3800 Series II and Series III engine/ L67 vs L32
    By DoUEvenShift NoBroItsAuto in forum Introductions/Noob Questions
    Last Post: 03-14-2014, 01:12 AM
  3. leaking coolant at TB, possible top swap with series 3 on to a series 2 block?
    By anarchy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-14-2013, 03:54 PM
  4. Spun rod bearing in my engine, Series III is cheaper than Series II, should I?
    By Booba5185 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-14-2013, 10:33 AM
  5. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
