Thread: alternative to SC oil?
Results 1 to 20 of 30
  1. #1 alternative to SC oil?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    My car is fixed and sitting in a parking lot at my fathers job, I need to get it today but the SC only has one bottle of oil in it. Where he works has access to all kinds of normal oils Just not SC oil. Im getting a ride there so I cant stop along the way to get some GM SC oil. Is there anything I can run in it, for a week or two?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: alternative to SC oil?
    Buffalo
    Pick up your car and stop at dealer on the way home
  3. #3 Re: alternative to SC oil?
    May 2008
    Schuyler, NE
    Mobile 1 5w30.
  4. #4 Re: alternative to SC oil?
    Buffalo
    No...
  5. #5 Re: alternative to SC oil?
    Aug 2013
    McDonald PA
    Mobile 1 5w30.
    This. I heard it has to be synthetic tho
  6. #6 Re: alternative to SC oil?
    Buffalo
    Yeah....
  7. #7 Re: alternative to SC oil?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    I just run vegetable oil in mine.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  8. #8 Re: alternative to SC oil?
    Buffalo
    So let's look at this to kill some time
    http://www.kennebell.net/KBWebsite/C...chargerOil.pdf
    those are some pretty bold claims
  9. #9 alternative to SC oil?
    Mercer, Pa
    Supercharger oil is very thin. Mobile one is to thick. Take the belt off and drive until you get the correct oil.
    http://www.ebay.com/ulk/itm/251903519631
  10. #10 Re: alternative to SC oil?
    GXP Level Member
    Mar 2015
    Tomball
    ^^^^this. As long is it is Nye 605 use it. It doesn't smell like a bag of assholes for no reason.
    Jeff
  11. #11 Re: alternative to SC oil?
    Sep 2014
    Richmond Virginia
    There is a dealer 10 minutes down the road, im planning to go there after I get the car and add it in the parking lot.
  12. #12 Re: alternative to SC oil?
    Incase you want to read another thread on it.
    http://www.grandprixforums.net/threa...c+supercharger
  13. #13 Re: alternative to SC oil?
    Sep 2014
    Richmond Virginia
    13$ a bottle
  14. #14 Re: alternative to SC oil?
    Buffalo
    I paid that for 2 from my dealer
  15. #15 Re: alternative to SC oil?
    GXP Level Member
    Mar 2015
    Tomball
    Really? I mean the oil lasts almost indefinitely, in sooo many cases it outlasts the entire car. Don't be a cheap ass on this one it may come back to haunt you later. As long as it isn't leaking it will stay in there. The bigger question is why is your level so low in the first place?
    Jeff
  16. #16 Re: alternative to SC oil?
    Of course using the "correct" oil is always best but if you look at the similar ratings that 0W20 has, it's likely a reason why some have used it.
    The real stuff is better in some of the extreme situations but overall they are similar in the real world. I was a rebel and used it lol.
  17. #17 Re: alternative to SC oil?
    Buffalo
    From that article I posted , I guess it means more HP lol
  18. #18 Re: alternative to SC oil?
    May 2008
    Schuyler, NE
    Hell, I drove for a year and a half with Mobil 1 5-30 in the sc, and never had a problem. It's not going to make any difference, going 10 miles down the road.
  19. #19 Re: alternative to SC oil?
    Mercer, Pa
    I've rebuilt more than 100 snouts, ones with motor oil are bad. You want to use it for 10 miles go ahead. I've used supercharger oil for 150,000 miles.
  20. #20 Re: alternative to SC oil?
    May 2008
    Schuyler, NE
    What's bad about them?
  1. Alternative Use for PB Blaster
    By Impala131 in forum Off Topic Discussion
    Last Post: 09-16-2014, 12:47 PM
  2. gmpartsdirect alternative?
    By Jordan5066 in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2013, 01:13 AM
  3. Alternative for remote wire?
    By jakeanator in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2013, 11:24 PM
  4. headlight alternative
    By 99gpse in forum Visual/Body Modifications
    Last Post: 12-11-2008, 09:59 AM
  5. Alternative fix for stripped threads
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2008, 05:03 PM
