Once it got cold out my GP became hard to start...it will struggle for about 5 seconds in the morning, sputter like its going to start and die out. Sometimes I need to try 3 times. After the initial hard start it is just fine for the rest of the day. I have recently cleaned the throttle body and replaced the spark plugs and wires so those can't be blamed...I checked the fuel pressure and with 0 pressure in the line it jumps to about 60 psi as soon as the key goes on, and seems to stay at 60psi while idleing. I noticed occasionally the needle was bouncing very rapidly between 55-60psi. Is this too high? Does the car even have a fuel pressure regulator?
Thanks
