Thread: LIM vacuum T
Results 1 to 3 of 3
  1. #1 LIM vacuum T
    GTP Level Member PaintChips97's Avatar
    Apr 2015
    Illinois
    Cracked the vacuum T that runs to the LIM under the SC snout. Is there a metal replacement?
    04 Comp G - a few mods, lots of OEM+ goodness, shiny stuff
  2. #2 Re: LIM vacuum T
    no. you go to advance auto. they got a wall full of vac T's you want the two pack of little white t's and 6 inches of vac line.
    cut 3 lengths of vac line a inch and a half long and put them on the new t. the old lines you may need to cut the old vac t off if it dont slide off the hard line, then push the hard line in the new vac lines on the new t. install the t on the lim, your all set.
  3. #3 Re: LIM vacuum T
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by ScottyDoggs View Post
    What this guy says... yes, you can get new tees at the dealer if you'd like, but for less money you can build a brand new vacuum tree set with auto store parts.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. WTB: MAP sensor vacuum hose or vacuum tees
    By Dschroeter63 in forum Wanted To Buy - Parts
    Last Post: 09-22-2013, 02:23 PM
  2. Help with vacuum T's
    By Nickell in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 07:07 PM
  3. Need Some Vacuum Help
    By gtpeddie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2012, 11:33 AM
  4. vacuum?
    By stonecold0469 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2012, 05:29 AM
  5. vacuum
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-05-2009, 09:09 PM
