Thread: Changing the coolant temperature sensor
Results 1 to 6 of 6
  1. #1 Changing the coolant temperature sensor
    Jun 2016
    USA
    When changing this sensor can you just use plumbers tape or do you need to use something liquid on the threads?
  2. #2 Re: Changing the coolant temperature sensor
    St. Louis
    I've used both in the past with no leaks either way.
  3. #3 Re: Changing the coolant temperature sensor
    GTP Level Member buickman104's Avatar
    NYC
    Yup, I've used both and haven't experience any leaks either.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: Changing the coolant temperature sensor
    Kemmerer, Wyoming
    I just installed the sensor with nothing. new sensors come with paste or something on them that will seal when they are new, but after that, you need tape or paste or something to seal it up.
  5. #5 Re: Changing the coolant temperature sensor
    Donating Users
    Kansas City
    The new coolant temp sensors usually do not come with any form of paste or sealant on the threads.
    Get plumbers paste or the sealant tape.
    I'd rather be safe than sorry since it's half sitting in coolant it's whole life.
    2012 Buick Regal Premium1 Turbo - White Diamond Tri-coat - 20% Tint - 5k HID Head/Fog Lights - ZZP CAI
  6. #6 Re: Changing the coolant temperature sensor
    Jan 2017
    xx
    I just installed a new coolant temp sensor a couple of weeks ago when I did the Gen V swap (broke my old one). Replacement came with sealant tape already on it. Put it in and noticed a coolant smell after a few days, it was leaking. Pulled it out and put a thin coat of RTV on and all is good.
  1. Replacing coolant temperature sensor
    By vertebrate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2013, 01:43 AM
  2. Changing Fan Temperature Settings
    By Chadgervais in forum General Tech Discussion
    Last Post: 02-05-2013, 03:58 PM
  3. Installing the Coolant Temperature Sensor Problems
    By ZackN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2011, 04:39 PM
  4. Harness for coolant temperature sensor
    By Duffman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2011, 07:13 PM
