Thread: flex plate replacement
Results 1 to 9 of 9
  1. #1 flex plate replacement
    Mar 2017
    Elizabethtown KY
    What is the easiest way to replace the flex-plate? ive been told i can undo the tranny and the rubber mount and drop the sub-frame a little bit and then undo the motor mounts and i can make up 4 inches of room which would be enough to do. But is it recommended? HELPPPP IM NEW TO FRONT WHEEL DRIVE 3800 IVE HAD A FEW 3800 CAMAROS.
    99 Pontiac Grand Prix #900 series 2 supercharged
  2. #2 Re: flex plate replacement
    Mar 2017
    Elizabethtown KY
    also been told to pull motor and to pull just trans im looking for the quickest and fastest way to do it
  3. #3 Re: flex plate replacement
    Removing the motor out the top would be the fastest if you ask me.
  4. #4 Re: flex plate replacement
    May 2008
    Schuyler, NE
    I tried splitting the two...I just ended up pulling the motor.
  5. #5 Re: flex plate replacement
    Mar 2017
    Elizabethtown KY
    when i put the bolts back in what torque are they supposed yo be at?
  6. #6 Re: flex plate replacement
    i went german spec "goodentight" on them botls, and reused the old ones.
  7. #7 Re: flex plate replacement
    SE Level Member Monday's Avatar
    May 2012
    Danielleland
    I call it a coolant swap. Unhook electrical..a few bolts and lift up 6 inches. Swap and drop
  8. #8 Re: flex plate replacement
    May 2008
    Schuyler, NE
    Quote Originally Posted by thewickedwitch99 View Post
    Are you talking about the flexplate bolts? Or block to transmission bolts?
  9. #9 Re: flex plate replacement
    May 2012
    Danielleland
    Starter, flex to convertor, exhaust to dp, trans bracket to different, trans bolts. Everything needed to lift it out
  1. Broken Flex Plate
    By indygrandprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-01-2014, 05:58 AM
  2. Transmission flex plate????
    By ItaliaGTP35 in forum General Grand Prix Discussion
    Last Post: 02-10-2014, 01:40 PM
  3. flex plate
    By Eric Whitter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-31-2013, 09:52 PM
  4. flex plate
    By tihosick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2009, 10:25 AM
