Thread: Rattling/Ticking Noise
Results 1 to 5 of 5
  1. #1 Rattling/Ticking Noise
    SE Level Member shaneh17's Avatar
    Sep 2014
    North Carolina
    Was hoping you guys could help me figure out what this noise is. Video is taken from the passenger side wheel under the car.
    ZZP Downpipe, PCM, 3.5 pulley, 180 T-Stat, PLOG, Devils Own Meth Kit
    13.76 @ 99.5 mph (before the meth)
  2. #2 Re: Rattling/Ticking Noise
    Video is private.
  3. #3 Re: Rattling/Ticking Noise
    Sep 2014
    North Carolina
    Does it work now?
  4. #4 Re: Rattling/Ticking Noise
    Jan 2014
    AR
    If its the same noise as this... (click pic for vid, it goes to Photobucket) take off the flexplate cover (plastic) with engine off and see if you can easily slide the starter gear back and forth on the shaft with a finger. If so, replace starter. It should snap back. Mine got real loud on turns, its jacked up on one side in the vid so it would make the noise. Sounds like yours.
  5. #5 Re: Rattling/Ticking Noise
    Sep 2014
    North Carolina
    Quote Originally Posted by idrivejunk View Post
    Thank you! Sounds are almost identical. Glad is nothing too major.
  1. Rattling noise 05 gtp
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 08-12-2014, 08:51 PM
  2. Weird rattling noise
    By vtechkiller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2012, 07:14 AM
  3. Rattling noise please help
    By n00bftw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2010, 12:15 AM
  4. Rattling noise from the front of engine
    By tjhgtp86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2010, 10:10 AM
  5. Loud Rattling Noise
    By Dangerous313KidInAPrix in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 05:18 PM
