Thread: Plug advice
Results 1 to 9 of 9
  1. #1 Plug advice
    SE Level Member USonuMabeaCh's Avatar
    Sep 2015
    gulf breeze, fl
    So I finally ordered a grip of parts...
    I'll be sitting at:
    CAI
    SD headers
    1.9 rockers
    all poly mounts
    LIM
    160 tstat
    3.2 pulley
    overkill canned PCM tune for aforementioned mods
    Now, I know that the 3.2 might have been a rash choice, but I'm going to see if I can get it to work safely with everything else, if not, I'll go up from there based on how much KR im getting. That said, what plugs would you guys recommend? 103s?
    Appreciate any input!
    02 40th GTP 2dr SSEI IC ZZP system with 3.2" Wizaird CAI Transgo SK SD headers aeroforce w/WB 1.9s over kill tune | 70 Skylark 455 bored to 462 Stg 1 iron heads ported 270 in 205 ex spx intake 870 street avenger 2" headers 3" xpipe flowmaster 40's full msd ign custom cam 540 hp 560 lbft TH400 2800 stall hotchkis susp DTS 12 bolt 3.42 rear
  2. #2 Re: Plug advice
    103's and a 160 are too cold. It's not like the old days were cooler is better, today's cars prefer temps above 180.
    Go with a 180 and 104's or 605's Auto lite plugs.
    3.2 might be at the max of the injectors, with a canned tune more than likely they will be. It will run it rich to save the motor really.
    Hopefully you bought a wideband and some sort of scangauge to monitor these things aswell.
  3. #3 Re: Plug advice
    just get a 3.4 pulley. i had the same mods and had KR until it was tuned. 3.4 is the limit for most unless you add a a IC to the mod list, or e85
  4. #4 Re: Plug advice
    Sep 2015
    gulf breeze, fl
    well, from the two forums (this one and montecarloforum.com) I've checked the mod-guide stickies to, and most of the pulley guides I've seen on the plethora of 3800 performance parts dealers, the 3.2 looked like a safe bet (and I am getting a PCM from overkill, it just wont be specifically tuned to this car for a bit).
    I have a guy with a scanner that I will be checking for KR after everything's installed, but I'm probably going to get one of those setups where I can use my smartphone as a gauge, but that will probably after I upgrade my brakes and do some suspension stuff.
    I just cant decide from what Im reading if I'm still in the 104 range, or if I should go for 103s, my assumption is Im closer to the 103 with this setup.
    If, after everything is installed, I'm getting knock, I'll go ahead and spend the money on a larger pulley.
  5. #5 Re: Plug advice
    Sep 2015
    gulf breeze, fl
    Quote Originally Posted by USonuMabeaCh View Post
    I guess I could say it a third time. I'm going to monitor it, as I have a guy with a scanner, and if I'm getting knock, I'll go up in pulley size.
    That said, I've decided that I'm probably going to throw an IC on it, and use the smallest pulley I can without having to upgrade the TB, MAF, fuel system, or transmission. I already ordered an aeroforce and wideband a/f sensor kit.
  6. #6 Plug advice
    LaBarge Supercharged sseilmnop's Avatar
    Mercer, Pa
    3.2 is a mistake.
    What vendor says headers and 1.9 rockers equals a 3.2 pulley?
    Adapters, Phenolic Intercoolers, Supercharger Parts & TVS2300
    http://stores.ebay.com/QualitySuperchargers
  7. #7 Re: Plug advice
    Probably ZZP
  8. #8 Re: Plug advice
    Mercer, Pa
    Quote Originally Posted by blueguy View Post
    Probably ZZP
    Funny. You will make more HP with no KR. A 3.2 is going to have a ton of KR compared to a 3.4 pulley.
    3.4 = more HP
    3.2 = more boost but less HP
  9. #9 Re: Plug advice
    Quote Originally Posted by sseilmnop View Post
    3.4 = more HP
    Truth.
    A larger pulley car with a leaner AFR, no KR, and either stock or more timing...will win 99% of the time.
    That other 1% of the time, you might get lucky...but it never ends well.
  1. spark plug advice
    By GTPSHAWTY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2015, 09:29 AM
  2. Need advice on stuck plug wire boots
    By CBWhite in forum General Tech Discussion
    Last Post: 03-05-2014, 09:00 PM
  3. 2008 Base model plug and plug wire swap
    By MS1227 in forum 04+ Specifics
    Last Post: 12-06-2012, 06:14 PM
  4. DRL's plug
    By GP24 in forum Visual/Body Modifications
    Last Post: 05-23-2012, 11:57 AM
  5. stock antenna plug to universal plug?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2012, 10:25 PM
