Hey all, 3800Pro is just about dead so I joined up to get ya'lls experience and advice on my vehicle.
I have a 2009 Buick Lacrosse with the L26 engine. Back in February I spent some of my tax return on parts. I ended up Intalling the HV3 Insert and ER Ratio Rocker Arms. I've been logging KR and AFR/Fuel Trims using Torque Pro for about 3 months now and I'm glad I did. Ended up with timing being pulled up to 5 degrees using 87 Octane so I upgraded to 93. Solved the KR issue.
Last week I decided to grab the Wiziared Intake. It arrived in the mail yesterday. I was initially giddy and couldn't wait to have it installed. I had issues getting everything lined up correctly but eventually got it taken care of. I took her out and played with her a bit and was thrilled by the new engine roar but I noticed it seemed to run a bit more sluggish. It definitely seemed my 70-110 time was slower than I remember. And yes I had the battery disconnected during install just to make sure I didn't damage the PCM connecting and re-connecting it.
Tonight I decided to take a look at my MAF rates. Torque Measures in CFM. After driving home from work I'm a bit worried.
At idle (800-900 rpm) which seems to be bit higher than it was before installing the intake, I was reading around 55CFM. Slight increase in throttle it jumped up to 125cfm. That seemed a bit high to me, I was hoping it was part of the re-learn procedure following the installation.
Now here comes the worrisome part.. At WOT on the interstate the MAF rate was 1400CFM!! Convereted to lbs per minute that's in the range of 128LPM.
I took it all apart and looked inside at the MAF and noticed what seemed to be a burnt carbon type smell. I've read carbon soot is normal with cold air intakes but the MAF seemed rather warm to the touch which didn't sit well by me.
Anyone ran this intake system before and can you tell me what your experiences were/what my issue may be.
I very well may need a tune but at this point I'm worried my MAF Sensor may go POOF as I'm riding along.
