Thread: UIM LIM repair help on parts
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 41 to 60 of 148
  1. #41 Re: UIM LIM repair help on parts
    i just broke the elbow before lifting the lim, as i wanted to lift it level so you dont leak coolant in the lim valley.
  2. #42 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    what webiste should i be using to upload pictures?
    this site is fighting me..
    ill try giving it a little more pull by the thermostat opening like you mentioned.
  3. #43 Re: UIM LIM repair help on parts
    up load to photobucket, then copy the url link, click the 3 rd icon from the right in reply, a window opens, click the url tab, paste in there, un check the box for a large pic.
  4. #44 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    [IMG][/IMG] okay two bolts under that tube do i unbolt?
  5. #45 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    [IMG][/IMG][IMG]<a
  6. #46 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    [IMG][/IMG]
  7. #47 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    [IMG][/IMG]
  8. #48 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    see any issues?
  9. #49 Re: UIM LIM repair help on parts
    i cant tell if the inside bolts are out, its full of oil, other then the bolts it looks clear to pop.
  10. #50 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    Id 100% got those bolts out haha. Hmmm. I can see the gaskets are melted to the outside of LIM maybe this is making it harder to lift off =/
    In this video around 10 minutes in the guy uses a crowbar to pry it off.
    https://www.youtube.com/watch?v=pJ_h...-6IAT&index=14
    I just can't figure out what leverage point the dudes using!
  11. #51 Re: UIM LIM repair help on parts
    under the t stat housing to the tranny or cross over pipe maybe good, just watch you dont smash the temp sensor doing it.
  12. #52 Re: UIM LIM repair help on parts
    in the vid it looks like hes using the cross over pipe to pry up under the t stat housing.
  13. #53 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    [IMG][/IMG]
  14. #54 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    Coolant sludge on both passenger side ports. Does this mean something? It wasn't like this on the driver side.
  15. #55 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    [IMG][/IMG]I think I see a failure =/
  16. #56 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    Thanks for the help man! I'll be back to it tomorrow!
    Gatta go to work.
  17. #57 Re: UIM LIM repair help on parts
    line the inside of the engine with rags right up to the ports. then scrape that crap out of the port there in the head. try to not let any fall in if you can help it.
    its just dex sludge build up. we all have it when we open up the lim.
  18. #58 Re: UIM LIM repair help on parts
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Green coolant FTW! How many miles were on your car when you did this?
  19. #59 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    I'm at 190K
    But it's also a second engine. (EST 120k)
    Car was handed down to me.
    I inherited a LOT of problems. lol
    I'm becoming a mechanic I can feel it. Haha
  20. #60 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    Quote Originally Posted by ScottyDoggs View Post
    A little coolant got in the engine, what should I do?
    Just dry with rags?
  1. 1998 GTP supercharger repair kits repair cost
    By SpecialK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2015, 10:49 AM
  2. Replies: 3
    Last Post: 09-01-2014, 10:59 AM
