Thread: UIM LIM repair help on parts
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 21 to 40 of 148
  1. #21 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    Also, having a hard time with these pesky fuel injectors. Im going to upload a picture can you show me? Pictures will be uploaded in minutes..
    1.. How to get these dang injectors off
    2.. Where the dang valve is.
  2. #22 Re: UIM LIM repair help on parts
    4 bolts hold the rail down, then use a pry bar to just gently pop the whole rail off in each corner.
  3. #23 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    UIM LIM repair help on parts Attached Images
  4. #24 Re: UIM LIM repair help on parts
    see wire clip on the side, push it in, then pull the plug off.
  5. #25 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    http://www.autotrend.us/gm/3800%20(2).jpg
    It wont let my upload another picture use this as reference for the valve cover please got this pic on google
  6. #26 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    1 or 2? Does this site have an upload size limit btw? my other pic just wont upload
  7. #27 Re: UIM LIM repair help on parts
    what you mean the valve cover? if the bar is over it unbolt it. theres 5 or 6 bolts holding it down around the outer lip. you may have to take the rear pull bracket off to get to the bolts. cant recall, mines gone for a long time now.
  8. #28 Re: UIM LIM repair help on parts
    see on the other side, make a left in the pic, the metal wire, push it in. and hold it in, then pull the plug off.
  9. #29 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    https://www.youtube.com/watch?v=OpwY...IM_WlFTTW-6IAT
    Figured the fuel pressure valve cover ordeal out haha ty.
    But help with the injector still please.
    Ty
  10. #30 Re: UIM LIM repair help on parts
    On the front of the injector where the metal clip goes around it, you push that in towards the injector body itself, push it in and down on the injector and then lift up on the whole thing.
    Picture limits are in place because they want you to link picture from a photosharing website like photobucket.
  11. #31 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    Oh figured it out ty back to work!
  12. #32 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    How to I detach these cables?
  13. #33 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    Sorry for the dumb questions guys, it's my first time wrenching on an engine.
  14. #34 Re: UIM LIM repair help on parts
    theres thingamudoodle on the end. aka a clip over the cable end. if you like you can just unbolt the tb and flop it off to the side with the cables still hooked up. what i did when i swapped my engine. you can still clean it up too. inside the back side of the tb. you'll see, its black thick carbon build up.
  15. #35 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    I just did exactly what you said haha, and saw exactly what you mentioned.
    I'm done for today, I'll be back tomorrow.
    What should I clean the throttle body with?
    Break cleaner right?
  16. #36 Re: UIM LIM repair help on parts
    that works fine. its best to take the maf out of the tb. you dont want anything to get on it but maf cleaner.
  17. #37 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    Can't get the dang LIM to pop off. Tips? I'm putting quite a bit of force on pulling it up.
    I got the two hidden bolts... all of the rest...
  18. #38 Re: UIM LIM repair help on parts
    if your sure you got the 2 bolts inside the lim the ones covered in oil, then it just takes a good pull, i just grabbed the t stat housing and gave it a jerk.
  19. #39 Re: UIM LIM repair help on parts
    Sep 2015
    Sacramento
    There's two bolts under the EGR tube i pried back. Do i take those off?
    Also, coolant elbow.. is that fighting me?
  20. #40 Re: UIM LIM repair help on parts
    hidden bolts are in the top right, and bottom left of the lim as show in the pic.
  1. 1998 GTP supercharger repair kits repair cost
    By SpecialK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2015, 10:49 AM
  2. Replies: 3
    Last Post: 09-01-2014, 10:59 AM
