Thread: Almost done with top swap, but in serious need of help
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: Almost done with top swap, but in serious need of help
    Barksdale AFB, LA
    why did you send out the l67 TB when you could have went at it with a dremel for an hour and done it for free. if youre going to buy a throttle body or pay for one you might as well get a northstar then.
    I'm getting the L67 TB ported for $50. Worth it since I don't have a place to do it right now. I also feel he'd do better work than I.
    2009 Subaru Impreza WRX STI
  2. #22 Re: Almost done with top swap, but in serious need of help
  3. #23 Re: Almost done with top swap, but in serious need of help
    Barksdale AFB, LA
    $50 is chump change compared to all the other stuff I'm getting. Worth it, seeing how a N* setup or LS1 is much more expensive and probably not necessary.
  4. #24 Re: Almost done with top swap, but in serious need of help
    Dec 2008
    Roxbury NJ
    because its a MAP sensor problem too. The MAP sensor for that throttle body is different. The engine is from a 98 bonneville. I would have to have custom tables put in the PCM and as stated before, I have a canned tune from ZZP. I also dont have the tools to do it. If you want pictures, I can show you why they are different and why I cant use the L67. I cant use one of the newer sensors in it either.
  5. #25 Re: Almost done with top swap, but in serious need of help
    Barksdale AFB, LA
    Quote Originally Posted by sickofsoyo View Post
    Not MAP sensor. MAF sensor. MAP sensor is different.
  6. #26 Re: Almost done with top swap, but in serious need of help
    Dec 2008
    Roxbury NJ
    Quote Originally Posted by Sabrewings View Post
    yes lol, I had the map sensor next to me when I was typing, putting that on soon
  7. #27 Re: Almost done with top swap, but in serious need of help
    Hoffman/Schaumburg, IL
    30 minutes with a saw, and dremel fixed that problem, and let me run the 99+ maf in my 98 TB..... Let me dig up the pics
  8. #28 Re: Almost done with top swap, but in serious need of help
    After porting w/ dremmel tool...I wish I had taken more pics.....
  9. #29 Re: Almost done with top swap, but in serious need of help
    Oh, and here it is whit the 99+ MAF
  1. top swap 05 gp
    By duane9586 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-05-2008, 06:28 PM
  2. Top end swap???
    By Randy_W in forum General Tech Discussion
    Last Post: 06-01-2008, 06:24 PM
  3. top swap
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 04:23 PM
  4. 97.5 pcm to 98 swap?
    By monte0 in forum PCM Tuning
    Last Post: 01-07-2008, 10:09 AM
