Thread: 97 Grand prix leaking coolant but not from radiator?
Results 1 to 20 of 20
  1. #1 97 Grand prix leaking coolant but not from radiator?
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    My 97 Pontiac Grand prix is leaking coolant but not from the radiator or the hose. So where could it be leaking from?
  2. #2 Re: 97 Grand prix leaking coolant but not from radiator?
    wheres the coolant hitting the ground?
  3. #3 Re: 97 Grand prix leaking coolant but not from radiator?
    Sep 2014
    New Orleans
    I see it's dripping under the timing belt then falls to the bottom of the engine
    Sent from my SM-N900T using Tapatalk
  4. #4 Re: 97 Grand prix leaking coolant but not from radiator?
    coolant elbow or the water pump.
    you have one elbow at the lim to the alt bracket, they break and leak, your year has a another cast elbow with a o ring on the alt bracket, that o ring can fail and leak.
    the water pump, car off, with two hands grab the w/p pulley then push with one hand, pull the other, then back and fourth, if you feel play the pump is bad, it leaks from under its snout out the weep hole there.
  5. #5 Re: 97 Grand prix leaking coolant but not from radiator?
    Sep 2014
    New Orleans
    Ok thanks for the advice my man ill check it out later on today. I guess i installed a new radiator hose for nothing
  6. #6 Re: 97 Grand prix leaking coolant but not from radiator?
    and the sucky hose to change at that.
  7. #7 Re: 97 Grand prix leaking coolant but not from radiator?
    Depends on which hose he changed.
  8. #8 Re: 97 Grand prix leaking coolant but not from radiator?
    Sep 2014
    New Orleans
    The coolant elbow is there right?
  9. #9 Re: 97 Grand prix leaking coolant but not from radiator?
    Yeah..and while yours isn't dry.. it's not soaked either.
  10. #10 Re: 97 Grand prix leaking coolant but not from radiator?
    Sep 2014
    New Orleans
    Does the coolant elbow supposed to be soaked if its leaking?
  11. #11 Re: 97 Grand prix leaking coolant but not from radiator?
    What you'd see is something similar to the pic..just not necessarily as orange..lol
  12. #12 Re: 97 Grand prix leaking coolant but not from radiator?
    Sep 2014
    New Orleans
    Lol damn ok I'll check my water pump also
  13. #13 Re: 97 Grand prix leaking coolant but not from radiator?
  14. #14 Re: 97 Grand prix leaking coolant but not from radiator?
    Sep 2014
    New Orleans
    I think it is my water pump the faster I spin it the more coolant leaks out 👀
  15. #15 Re: 97 Grand prix leaking coolant but not from radiator?
    sounds more like a coolant elbow. water pumps are a slow off on leak, leak more car off vs on too.
    take some pics and post em if you can of your elbow. my lower cast elbow did leak on me as well.
    cold engine, and off. follow the heater core hose tube at the alt bracket as it turns inside to the block, your fingers and hand will fit in there, if you feel its wet back there under where the cast elbow meets the block that elbow is leaking.
    got a good pic of what im talking about, see the left side pipe leads to the engine? follow the outer pipe to the timing cover.
  16. #16 Re: 97 Grand prix leaking coolant but not from radiator?
    It sounds like an elbow..when he gave us a picture of a non leaking elbow?
  17. #17 Re: 97 Grand prix leaking coolant but not from radiator?
    Enfield, CT
    Quote Originally Posted by Jason97GrandprixGT View Post
    Just so you are aware, we have timing chains not belts. What you are thinking of is the serpentine belt.
    Sent from my LG G3
  18. #18 Re: 97 Grand prix leaking coolant but not from radiator?
    Enfield, CT
    Maybe after he shut the car off the coolant dried off from the heat of the engine?
    Sent from my LG G3
  19. #19 Re: 97 Grand prix leaking coolant but not from radiator?
    Sep 2014
    New Orleans
    Finished installing the new water pump now I don't have any more coolant leaks thanks for the help everyone
  20. #20 Re: 97 Grand prix leaking coolant but not from radiator?
    No problem guy..
    I had no doubt once you posted the pic.
  1. Leaking Coolant 2001 Grand Prix
    By eric37428 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-01-2012, 11:53 AM
  2. 01Cooler Line leaking at Radiator??
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2011, 01:59 PM
  3. Transmission fluid leaking into radiator.
    By Fatboy58 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2010, 10:24 AM
  4. Transmission Cooler Line leaking at radiator
    By Obrigado in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2010, 04:36 PM
