Thread: 2007 grand prix shuts down at 5000rpm
Results 1 to 6 of 6
  1. #1 2007 grand prix shuts down at 5000rpm
    May 2015
    Chats
    I have an 07 gp na, when i get the rpms around 5k, the engine shuts down as if you turn the key off. It does this under load or if it is in neutral. I can start it right after it dies. I have checked all the wiring, redid the grounds and power wires, replaced the maf, cleaned throttle body. It runs great untill 5k. Had a scan tool hooked up to it, when it dies the tool loses connection with the pcm. Any ideas?
  2. #2 Re: 2007 grand prix shuts down at 5000rpm
    Chats
    83662
    Can the scan tool watch crank sensor and cam sensor functions??
    I wonder if one drops out, then it thinks the motor has shut off then it "stalls" the motor and loses power for a split second causing it to reset.
  3. #3 Re: 2007 grand prix shuts down at 5000rpm
    May 2015
    Chats
    It can, but it happens so fast that you cant tell if one of those shut it down. No engine codes either
  4. #4 Re: 2007 grand prix shuts down at 5000rpm
    Chats
    83662
    Try a case/crank relearn anyway.
    If the scanner is fancy enough it can do it.
    I'm not saying it's the crank sensor at fault because they normally will fail at random while cruising or at stop lights, it loses signal and shuts fuel/spark off and it stalls. They will likely never throw an engine code either because it's not a "hard" fault, all it does with watch for a signal and when it's not there it think you shut the key off and it follows.
  5. #5 Re: 2007 grand prix shuts down at 5000rpm
    May 2015
    Chats
    Ok, thanks
  6. #6 Re: 2007 grand prix shuts down at 5000rpm
    Jan 2019
    Iowa
    Chats
    Quote Originally Posted by mvlasak View Post
    Ok, thanks
    This is a super old thread. But, I have the same issue on my car after an engine swap. Did you ever find out what was wrong?
  1. 2000 Pontiac Grand Prix Shuts off without warning while driving.
    By geeksweep in forum General Tech Discussion
    Last Post: 09-13-2015, 03:08 PM
  2. 2001 Grand Prix starts up and shuts off in seconds.
    By pinkdervish in forum General Grand Prix Discussion
    Last Post: 01-20-2014, 03:42 PM
  3. 94 Grand Prix after driving 20 miles it shuts down...???
    By AMXTRA in forum General Tech Discussion
    Last Post: 07-24-2012, 01:13 PM
  4. 2007 Grand Prix
    By kristinkay in forum Introductions/Noob Questions
    Last Post: 07-29-2010, 02:23 PM
