Thread: 02 3.8l maf malfunction ?
Results 1 to 18 of 18
  1. #1 02 3.8l maf malfunction ?
    SE Level Member GERRY's Avatar
    Jan 2013
    Montreal QC CANADA
    I.m sure this has been discussed many times.For some reason I cant figure it out. I recently changed my cai filter and lo and behold the check engine light lit up. The car runs like crap and stalls out on me at lights. Is there an adjustment or asomething i can do to the throttle body or something? Or do I have to change my maf agaion. Any help wold be appreciated. THAnks
  2. #2 Re: 02 3.8l maf malfunction ?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    What code is it throwing?
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: 02 3.8l maf malfunction ?
    Jan 2013
    Montreal QC CANADA
    It`s giving me a p0102 for the moment. It was giving me an 02 code too but cant remember what it was right now. The 020 code is gone now though
  4. #4 Re: 02 3.8l maf malfunction ?
    Jan 2013
    Montreal QC CANADA
    P0440 was the 02 code I was throwing I believe.
    I also removed the throttle body screen when I changed my filter. Would that maybe cause my problems ?
  5. #5 Re: 02 3.8l maf malfunction ?
    Apr 2012
    Dayton, OH
    No idea, but I would put it back in. If it doesn't make anything better see if the car runs better with the MAF unplugged.
    2012 F150 STX
  6. #6 Re: 02 3.8l maf malfunction ?
    Yes.. it can. Put it back in and likely your issues will go away. If not.. you might have had too much oil on the filter and if it lands on the maf.. the maf is toast
  7. #7 Re: 02 3.8l maf malfunction ?
    Jan 2013
    Montreal QC CANADA
    I didnt think it made a difference. Ill put it back in in the morning. Thanks
    I didnt put a new reuseable. I grabbed what ever cone fit off the shelf at work and put it in. It's from a E250 I think.
  8. #8 Re: 02 3.8l maf malfunction ?
    Jan 2013
    Montreal QC CANADA
    I reinstalled the screen. I pulled the plug from the maf it idled a bit better. So I figured its the maf. I changed it and boom it runs sooooooo baaaad now. 100% worse than it was. The idle is all over the place and it just wants to die. Whatd I do wrong
  9. #9 Re: 02 3.8l maf malfunction ?
    What MAF did you use?
    04 Comp G.
  10. #10 Re: 02 3.8l maf malfunction ?
    Jan 2013
    Montreal QC CANADA
    I used a cheap rich porter model. I guess that's the problem isn't it.
  11. #11 Re: 02 3.8l maf malfunction ?
    Jan 2013
    Montreal QC CANADA
    At a cost of 168 plus taxes. So not too cheap
  12. #12 Re: 02 3.8l maf malfunction ?
    Apr 2015
    Columbus, OH
    Ouch. I have a used one that I know works I'll send you for 20 + shipping. Or 1000 Canadian. Never was good with conversions.
    Top Swapped 01 Imp
  13. #13 Re: 02 3.8l maf malfunction ?
    Jan 2013
    Montreal QC CANADA
    Gonna swing by the scrap yard this weekend. 1000 is a bit more than I wanted to pay lol
  14. #14 Re: 02 3.8l maf malfunction ?
    Yea grab a used oem one anything besides oem seem to never work right
    04 Comp G.
  15. #15 Re: 02 3.8l maf malfunction ?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I've had OK luck with the Cardone Reman MAFs, but I believe those are just OEM MAFs that have the solder joints fixed. Might be another good option to look into. I have used 3 and all seemed to work great.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  16. #16 Re: 02 3.8l maf malfunction ?
    Jan 2013
    Montreal QC CANADA
    I got 2 used maf sensors yesterday. Both the same results now. P0102 and p0140 now. Do I have to change my o2 sensor now? Could it be a voltage issue maybe ? My battery is a bit old. On my machine at work it says its health is at about 65%
  17. #17 Re: 02 3.8l maf malfunction ?
    Apr 2012
    Dayton, OH
    Check #21 fuse underhood
    2012 F150 STX
  18. #18 Re: 02 3.8l maf malfunction ?
    Jan 2013
    Montreal QC CANADA
    Turns the o2 code was a cur wire Luckily I have a spare one. I got a used maf from a local garage that came off a 03 gs. I popped it in cleared the codes and started it up. All is good after about 200 kms.
  1. heater malfunction
    By randyp in forum Introductions/Noob Questions
    Last Post: 12-31-2011, 05:20 PM
  2. temp gauge malfunction
    By Mastiff in forum General Tech Discussion
    Last Post: 08-23-2011, 01:01 PM
  3. Interior light malfunction
    By 99blkgt in forum General Tech Discussion
    Last Post: 11-30-2010, 10:08 PM
  4. Window malfunction
    By dagger in forum General Tech Discussion
    Last Post: 04-15-2010, 07:47 AM
  5. NEED HELP: Speedometer malfunction and car jerks
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-11-2010, 08:39 PM
