Thread: Finally Decided! Have some questions though?
Results 1 to 4 of 4
  1. #1 Finally Decided! Have some questions though?
    Jan 2015
    Michigan
    I finally decided after debating turbo, top swap, or staying na. I decided to top swap because it is cheaper than turbo and i can make good power. But i have some questions. I am going to be buy the parts over the summer and want to have headers, dp, and an intake before i top swap it. But should i install the headers and dp before i top swap it or do it all at once? Im just concerned about the low end torque loss. will it be noticeable? should i not worry about it while im getting the other parts all together? thanks
  2. #2 Re: Finally Decided! Have some questions though?
    Apr 2012
    Bancroft. Ontario, Canada
    headers come with their own DP
  3. #3 Re: Finally Decided! Have some questions though?
    St. Louis
    Why would you go through all the trouble of installing headers now, when all you will have to do is take them off again when you go to install the S/C heads along w/ the other top swap parts?? That's double the work. I'd wait until you have everything you need in hand (don't forget gaskets, headbolts, fluids,plugs/wires,etc) and then do it all at once.
  4. #4 Re: Finally Decided! Have some questions though?
    Antioch, IL
    top swap is crap, tear down to a short block, to put stock things back on.............
    2009 Challenger SRT8
    Expert at being gay.
  1. So I finally did it... Have a few questions..
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-26-2011, 12:56 PM
  2. Decided to go with coilovers, rears almost finally done (Updated 11/11)
    By BlownBigBlock in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2011, 09:18 PM
  3. So I've decided on how far I'm going with my mods....
    By starscream5000 in forum 04+ Specifics
    Last Post: 03-25-2011, 09:18 PM
  4. Finally decided and purchased a 3rd car.....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-15-2008, 12:07 AM
  5. well i decided about my gt
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 11:58 PM
