Thread: Opinions on SLP air box.
Results 1 to 13 of 13
  1. #1 Opinions on SLP air box.
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    I am looking at buying an slp airbox and was looking for some opinions on these particular setups. They don't look too much different than the stock airbox aside from not having the baffles in the box and using the cone filter instead of the stock type. Would this be worth buying or would just throwing in a k&n filter in the stock box be good enough? My car is just a daily driver.
    Thanks!
  2. #2 Re: Opinions on SLP air box.
    Jersey
    there is plenty better intakes than SLP's. Wizard is the best and then there are fender well intakes.
    16' wrx sti- stock
  3. #3 Re: Opinions on SLP air box.
    TDCRacing
    Guest
    Over priced and over rated.
  4. #4 Re: Opinions on SLP air box.
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by TDCRacing View Post
    x 2
  5. #5 Re: Opinions on SLP air box.
    x3.
  6. #6 Re: Opinions on SLP air box.
    May 2008
    Ontario
    Would there really be any benefeit to the slp box instead of just dropping in a k&n panel filter?
  7. #7 Re: Opinions on SLP air box.
    TDCRacing
    Guest
    None at all.
  8. #8 Re: Opinions on SLP air box.
    Jersey
    Don't put in a k&N drop in filter, with my experience the oil on the filter clogged up my MAF sensor, therefore i had to replace it. K&N drop in's are a rip off. No performance what so ever. Save your $50.00
    16' wrx sti- stock
  9. #9 Re: Opinions on SLP air box.
    TDCRacing
    Guest
    If you had oil on you're mas air flow sensor then you over oiled you're filter.
  10. #10 Re: Opinions on SLP air box.
    Jersey
    I didn't oil it at all. I took it straight out of the box and slapped it in.
    16' wrx sti- stock
  11. #11 Re: Opinions on SLP air box.
    TDCRacing
    Guest
    Yeah a lot of people do over oil theres though. In my opinion they are overoiled from the factory. If you look at the bag they come in there's oil all over the bag.
  12. #12 Re: Opinions on SLP air box.
    Barksdale AFB, LA
    I'm going with AEM Dry flow when my K&N is in need of servicing. I'm done with oil based air filters.
    2009 Subaru Impreza WRX STI
  13. #13 Re: Opinions on SLP air box.
    May 2008
    Ontario
    Hmm, I have heard something before about the oil on the k&n's being bad for maf sensors. I figured as long as it was not over oiled it would be fine. I looked at the one for our cars and it is quite a bit thinner and less restrictive looking than a stock paper filter.
  1. opinions on this??
    By fabz77gp in forum General Tech Discussion
    Last Post: 10-17-2008, 11:57 PM
  2. I need OPINIONS PLEASE
    Last Post: 09-11-2008, 09:11 PM
  3. opinions on zzp 1.0 PCM
    By 2000GTP in forum PCM Tuning
    Last Post: 09-10-2008, 06:36 PM
  4. Mod opinions?
    By Mvfootball1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2008, 08:07 AM
