Thread: Low Coolant light on
Results 1 to 4 of 4
  1. #1 Low Coolant light on
    May 2012
    Jacksonville, Fl
    I have a 2002 GP GT non superchaged 3800. My low coolant light burns all the time once the engine is started. However, the Temp gauge registers well within the normal range and checking the radiator it is full and and the coolant jug has fluid at the proper level. Can someone tell me what I need to replace or check ? Thanks in advance, Bill.
  2. #2 Re: Low Coolant light on
    There is a sensor on the rad itself, on the side tank under the rad cap.
    You can either test the circut, replace the sensor or just unplug it and never have the light come on again, but then you'd have to check it more often.
  3. #3 Re: Low Coolant light on
    I break stuff selliott's Avatar
    Kansas City
    Just unplug it
  4. #4 Re: Low Coolant light on
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    X2 on unplugging, f that stupid sensor.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. Low coolant light?
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2009, 01:13 PM
