Thread: battery to starter terminals
Results 1 to 8 of 8
  1. #1 battery to starter terminals
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    I want to install and upgrade new wires connecting my battery and starter. How should I install it.
  2. #2 Re: battery to starter terminals
    Remove the old one, then install the new one the same way the old one was.
    one end is on the battery, un hook that side first, then the other end is on the starter motor. the ground cable is close to the starter on the trans bell housing bolt. same deal remove, and replace it.
  3. #3 Re: battery to starter terminals
    Sep 2014
    New Orleans
    Ok but it have my hot wires on the starter motor wrapped up. I don't want to cut it and mess something up
  4. #4 Re: battery to starter terminals
    its likely in a wire loom, take the tape off the ends. the cable should come out the slit in the wire loom. (the plastic covering there.)
  5. #5 Re: battery to starter terminals
    Sep 2014
    New Orleans
    Yea it is in a wire loom and ok I'll try to do it tomorrow because I do have a lot of corrosion on my cables connecting the battery and starter
  6. #6 Re: battery to starter terminals
    you can just clean that up and re use it, a wire brush goes a long way, clean the cable side, and the battery. pretty sure the parts store sell some kinda spray on cleaner too.
  7. #7 Re: battery to starter terminals
    Sep 2014
    New Orleans
    Yea I did spray some on and it still won't start sometimes. And I replaced everything on my car except the battery terminals. I really want to upgrade the starter wires to 4 gauge also like I have my battery to alternator set up
  8. #8 Re: battery to starter terminals
    i hear ya, look up the big 3. its a up grade for the all the grounds and power cables alt to fuse box and so.
  1. New Battery, New Alternator, Battery still dies. Any Ideas?
    By bjornbjorn in forum General Tech Discussion
    Last Post: 03-19-2015, 10:05 PM
  2. Replies: 3
    Last Post: 01-31-2015, 10:56 AM
  3. Battery Terminals
    By gordster1122 in forum General Tech Discussion
    Last Post: 07-19-2013, 07:48 PM
  4. Bad starter???
    By rell2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-13-2012, 09:27 AM
  5. Diagnosing corrosion on coil pack terminals
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2008, 01:52 PM
