Thread: Help reading plugs
Results 1 to 4 of 4
  1. #1 Help reading plugs
    GT Level Member natethegreat's Avatar
    Brookings, SD
    Hey all, Just pulled a couple of plugs to see which ones i bought, and while doing so thought they looked kind of lean. I'm running a topswap on the stock pulley, and when i had it tuned he said it was tuned a little rich. Because of that i think it has fouled my 02. Also, my charger started to make noise, so my i just took the belt off for the time being until i could find another supercharger. It was stumbling for like half a second, but it does it with our without the belt. Anywho, here is the picture. I pulled two, and they both looked like that. Copper AL 103's.
  2. #2 Re: Help reading plugs
    Nah, thats still rich and too cold of plug.
    If you were lean the tip would be browner and the white with the electrode would not be black/brown near the top. It would be all white and almost like a chalk white coving it.
  3. #3 Re: Help reading plugs
    Brookings, SD
    Alrighty, thanks. Ill get some 104's instead
  4. #4 Re: Help reading plugs
    Brookings, SD
    Replaced all the plugs, so i figured id show you the rest.
    This is the rear bank, #6 is on the right, and smells like oil, but doesn't really look oil fouled. I don't think its a huge problem.
    And heres the front bank
  1. reading spark plugs?
    By jrb1027 in forum General Tech Discussion
    Last Post: 06-23-2014, 05:14 PM
  2. Reading MAF in Hz?
    By 94GrandPrixSE in forum PCM Tuning
    Last Post: 03-28-2014, 04:13 PM
  3. Platinum Plugs vs. Iridium Plugs
    By Eddie Jackson in forum 5.3L V8 (LS4)
    Last Post: 10-17-2012, 10:55 AM
  4. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  5. MAP reading
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2009, 12:34 AM
