Thread: po 404 /405 issues
Results 1 to 9 of 9
  1. #1 po 404 /405 issues
    SE Level Member lostscout's Avatar
    Sep 2014
    Cold Lake Alberta Canada
    anyone got any ideas...since my previous difficulties, I am getting a constant po404/405 code..... valve is new...ish about 500 miles
  2. #2 Re: po 404 /405 issues
    check the wires to the egr, they maybe damaged,. cracks, missing insulation will cause those codes. or the egr is bad.
  3. #3 Re: po 404 /405 issues
    When you list a code, please list the name. It helps us out by not having to look it up for you. I get the impression that some folks are lazy and don't research and issue...they post and figure someone else will do the work.
    Check the 5 volt and ground references
  4. #4 Re: po 404 /405 issues
    Sep 2014
    sorry Bill...I'll get back to you...something about #1 wire low?
  5. #5 Re: po 404 /405 issues
  6. #6 Re: po 404 /405 issues
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I get a random P0404 sometimes, my solution is going to be an EGR delete lol.
    2012 F150 STX
    - Gonna be a race truck
  7. #7 Re: po 404 /405 issues
    or just leave the egr and delete the codes. what i did to my car. sick of it popping up from time to time, same for the evap. deleted, in all i got like 12 deleted codes lol
  8. #8 Re: po 404 /405 issues
    Sep 2014
    hmmmm how is that done so no cel comes on?
  9. #9 Re: po 404 /405 issues
    i have a dhp tuner, with a tuner program and hardware you cant set the codes to not report. and they show ready on a obd2 scan at inspection.
  1. Few issues I'd like to fix
    By genki in forum General Tech Discussion
    Last Post: 08-14-2013, 02:14 PM
  2. lcd tv issues
    By kuntzie in forum Off Topic Discussion
    Last Post: 01-06-2012, 11:09 PM
  3. I have issues
    By BillBoost37 in forum The Rant Forum
    Last Post: 01-06-2012, 04:10 PM
  4. H.I.D Issues...need help?
    By Pontiacman76 in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2011, 08:23 PM
  5. A/C Issues
    By ReaperRob in forum General Tech Discussion
    Last Post: 08-10-2009, 09:55 PM
