Thread: '04 Grand Prix Cold Weather Stalling
Results 1 to 6 of 6
  1. #1 '04 Grand Prix Cold Weather Stalling
    Feb 2015
    MO
    My 2004 Grand Prix (GT2, non-supercharged) has a cold-weather stalling problem. The car has 170k miles on it. The fuel filter is about 2 years old, fuel pump is 1 year old, and the MAP and MAF sensors are both newer as well.
    This problem only happens when it is COLD outside (like 15 F or colder). The car starts fine, and then completely stalls after about 5 minutes of driving. The car will crank, but not restart for about 5 minutes. After it does restart, it runs fine.
    The CEL does not turn on, and no codes are stored. I bought a BlueTooth OBDII scanner to watch various sensor readings while driving, and was able to replicate the stalling today with the scanner turned on. When it stalled, the MAF reading went to almost zero (makes sense betcause the engine was not running), but the throttle position did keep going up and down as I operated the throttle. The engine RPM would should about 200 RPM when I was cranking the engine, and it wasn't starting. This leads me to believe that it has either a fuel or ignition problem, and that the crankshaft position sensor and electronic throttle are fine (otherwise it would show 0 RPM while cranking, and the throttle position would not have been moving).
    I could hear the fuel pump priming when I turned on they key, but the car would not start. A fuel filter problem would seem odd, because I don't see it causing a complete stall. However, I'll replace it this weekend anyway.
    Any other problems that anyone can think of? Again, this only happens when it is COLD out - the car ran fine when it was 35 degrees the other day. Are there any other sensors, fuel, or ignition components that could be affected by the cold like this?
  2. #2 Re: '04 Grand Prix Cold Weather Stalling
    could be the fuel pressure regulator. take its vac line off see if it smells of gas, or if gas comes out the line after it stalls.
  3. #3 Re: '04 Grand Prix Cold Weather Stalling
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Have you tried disconnecting the maf and seeing how it did?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  4. #4 Re: '04 Grand Prix Cold Weather Stalling
    Aug 2013
    arlington, tx
    What brand MAP sensor did you buy?
  5. #5 Re: '04 Grand Prix Cold Weather Stalling
    Feb 2015
    MO
    I used an AC Delco MAF sensor and I believe a Borg Warner MAP sensor. The car does not have a fuel pressure regulator, so I'm not able to replace that.
    It was in the 30's out yesterday and the car ran perfect. I bought a spark tester and will test for spark the next time it dies on me. This will hopefully isolate the problem to either a fuel problem or a spark problem.
  6. #6 Re: '04 Grand Prix Cold Weather Stalling
    Aug 2013
    arlington, tx
    I was having a similar problem to yours. It would turn on but after I drove and went past 1500 rpm, it would start to hesitate and stall out if I gave it anymore gas. It turned out to be the MAP sensor that I bought from O'reillys. Bought a new OEM one from NAPA and that took care of it and this was AFTER I bit the bullet and took it to the dealership to get it diagnosed since I was completely out of ideas and they told me what the problem was. Before I took it to the dealership, I tried everything. TB, MAF, crank sensor, etc.
    This was my issue, hope it helps. http://www.grandprixforums.net/threa...ight=luckyg817
  1. Just some cold weather pulls in the GP
    By CapnBreakAlot in forum Track Sessions and Kills
    Last Post: 11-19-2013, 05:51 PM
  2. cold weather brings cold engine
    By Garrett Mofford in forum Engine
    Last Post: 12-31-2012, 08:45 PM
  3. Washing Your Car in Cold Weather
    By Traeger2591 in forum Off Topic Discussion
    Last Post: 01-12-2010, 11:06 AM
  4. 04 grand prix gtp comp g and cold weather?
    By gritter in forum General Tech Discussion
    Last Post: 05-02-2009, 08:08 AM
