Thread: what ratio rockers are best for a N/A?
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 what ratio rockers are best for a N/A?
    Dec 2014
    Austin, TX
    00 grand prix gt, 2.5" DP, zzp powerlog and pcm, l26 uim swap, l67TB and DIY cai, but otherwise stock besides suspension. i was looking at the yella terra rockers on intense, and i noticed they now offer them in 1:6,1:7,1:8, and 1:9. I heard somewhere that the 1:9 is too much for the N/A motor, but i dont know if thats true. my goal for this car is to add as much fun to it as i can without destroying the gas mileage because its my daily driver. also, does anyone know what kind of gains an N/A motor gets from high ratio rockers? all the numbers ive seen are questionable advertising about supercharged gains.
  2. #2 Re: what ratio rockers are best for a N/A?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    As long as your n/a, stock rockers are the best. There's really not much of a gain to be had with them.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  3. #3 Re: what ratio rockers are best for a N/A?
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Have you thought of doing an hv2 from zzp or a GT1 cam?
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #4 Re: what ratio rockers are best for a N/A?
    Dec 2008
    Lawndale, CA
    ER Split Ratio Rockers.
    Check out my mod list. My grand prix is my daily driver.
  5. #5 Re: what ratio rockers are best for a N/A?
    Jul 2012
    Chicago
    ER Rockers have the best gains in NA.
    -Carl
  6. #6 Re: what ratio rockers are best for a N/A?
    Dec 2014
    Austin, TX
    OK, so EGR are the way to go. is there a reason that they are better then the yella terra ones? I just thought that YT was like the "gold standard" when it comes to rockers. and does anyone have hard numbers regarding gains?
  7. #7 Re: what ratio rockers are best for a N/A?
    Dec 2014
    Austin, TX
    Quote Originally Posted by Travisgt2 View Post
    I have heard so many mixed reviews about the hv2 insert that i really hadnt considered it to be of much use. Really been thinking bout the GT1 cam though. I'm just worried that if I get the cam instead of the rockers, i'll never have the time or tools to actually install the damn thing. dont you have to yank the engine out to swap the cam?
  8. #8 Re: what ratio rockers are best for a N/A?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    its hv3 now, and i noticed more topend pull with it
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  9. #9 Re: what ratio rockers are best for a N/A?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I'd contiboot about hv3 difference vs stock but mines still in my toolbox lol.
    2012 F150 STX
    - Gonna be a race truck
  10. #10 Re: what ratio rockers are best for a N/A?
    Aug 2012
    To do a cam you can either drop the sub-frame and go through the wheel well, or you can pull the engine.
  11. #11 Re: what ratio rockers are best for a N/A?
    GT Level Member bachert24's Avatar
    Jan 2015
    Few notes. First, if anyone tells you that it's not worth it to increase rocker ratio, they don't know their car very well. If you don't want to machine your heads then your options are rockers or cam. If you don't mind machining the valve seats you can do both. Just remember that one makes your cam bigger, and the other makes your cam seem bigger. As far as the HV3 goes..in stock form it does help to aim your airflow. You'd see like 3hp increase on the bottom end. Maybe 10 on the top end. Couple the HV3 with the GT1 cam as I have, and you're looking at potentially 30+ hp increase at the top of your RPM band. Let me know if I can help you in any way. I'm in the middle of my build right now. My setup is:
    Rollmaster single timing setup
    GT1 cam
    New manley chromoly pushrods
    CTS-VR lifters
    LS9 valvesprings, seals, and retainers
    Self port and polish on the heads
    HV3 insert
    Iridium plugs
    Blue streak plug wires
    Cometic .052 mls headgaskets
    I'm expecting a 50hp bump at the crank or better.
    I'll be adding a centrifugal S/C down the road with about 15psi of boost.
    Sent from my Verizon LG G3 sexiness via tapatalk
  12. #12 Re: what ratio rockers are best for a N/A?
    Jan 2013
    leavenworth ks
    Quote Originally Posted by bachert24 View Post
    GT1 cam
    CTS-VR lifters
    HV3 insert
    Iridium plugs
    Don't forget your valve covers lol and I'm looking to do an hv3 and gt1 cam let us know how the rockers feel what's the price on those?
  13. #13 Re: what ratio rockers are best for a N/A?
    Aug 2012
    I only say it's not worth it when n/a because you are going to eventually hit a brick wall of performance. Once you are boosted it's a whole different story. I mean, yeah, you can make decent power when n/a, but you are not going to get as far as you would without some form of forced induction.
  14. #14 Re: what ratio rockers are best for a N/A?
    Jan 2013
    leavenworth ks
    Some of us don't want it that drastic some of us just like keep our DD all u guys s/c are so insistent on top swapping or turboing just suport some us n/a guys and help us lol
  15. #15 Re: what ratio rockers are best for a N/A?
    Apr 2012
    Dayton, OH
    N/a for life
    2012 F150 STX
  16. #16 Re: what ratio rockers are best for a N/A?
    Jan 2015
    You'll hit a brick wall for sure. But when I can just barely lose to a car that has $10k more into it than I do, I'll be smiling all the way to the back. Not to mention my car will be cheaper to fix, run cooler, and be more reliable :-)
  17. #17 Re: what ratio rockers are best for a N/A?
    Jan 2015
    Oh man, how could I forget those beautiful valve covers! Soon as i get this all installed I'll let you know how it feels for sure.
  18. #18 Re: what ratio rockers are best for a N/A?
    Jan 2013
    leavenworth ks
    There in the mail today
  19. #19 Re: what ratio rockers are best for a N/A?
    Enfield, CT
    N/a for life
    X2
    I think. . .... lol
  20. #20 Re: what ratio rockers are best for a N/A?
    Aug 2012
    I honestly don't know how to reply to that.... besides saying you're high if you think you'd beat another car that had 10k in parts alone on it...
  1. looking to buy ratio rockers
    By ScammingL67beast in forum Wanted To Buy - Parts
    Last Post: 12-22-2013, 04:27 AM
  2. 1.9 ratio rockers from ZZP
    By DBGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-28-2010, 11:13 PM
  3. ZZP ER ratio rockers vs ZZP ST2 cam
    Last Post: 06-24-2010, 12:03 PM
