Thread: '04 Valve Cover Gasket DIY
Results 1 to 3 of 3
  1. #1 '04 Valve Cover Gasket DIY
    May 2012
    Bloomington, IN
    Hey,
    Could use some insight on an '04 valve cover gasket diy. I've seen some for the older GP models (L36 vs L26) and wasn't sure if they were also relevant. Would a Bonneville or similar model diy be helpful? I'll be doing both gaskets and wanted to know if I need to drain coolant to get access which I've seen on some boards.
    Please let me know or pass along some other links, thanks in advance.
  2. #2 Re: '04 Valve Cover Gasket DIY
    Negative.
    No fluids have to be drained. I loosened the alternator bracket but didn't remove it. If you yank it out, then you'll have a mess of coolant everywhere, yes.
    I just did valve cover gaskets on a supercharged car...with everything on the car minus the belt/alternator and coil pack bracket.
  3. #3 Re: '04 Valve Cover Gasket DIY
    Jul 2014
    New Jersey
    At first i thought he was saying he was making his own valve cover gasket lol
  1. valve cover gasket
    By kawasakidrivinghick in forum General Tech Discussion
    Last Post: 02-22-2013, 04:59 PM
  2. Valve Cover Gasket?
    By Below Average Joe in forum General Grand Prix Discussion
    Last Post: 09-10-2012, 08:20 AM
  3. Valve cover gasket
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 05:11 PM
  4. Valve cover gasket
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 10:25 PM
  5. valve cover gasket
    By BFish in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-12-2008, 03:51 PM
