Thread: Timing Chain GASKET replacement
Results 1 to 6 of 6
  1. #1 Timing Chain GASKET replacement
    Nov 2014
    Indianapolis
    Hi guys,
    I have a 2007 grand Prix and it has a timing chain gasket leak (verified by two separate mechanics). I have searched the forums for a procedure on replacing just the gasket (vs. the chain) and have came up empty handed.
    My question is: Does anyone have a good procedure for changing the timing chain gasket (obviously the other gaskets up to that point too), or know of a good book that could point the way (Hayes etc)?
    Thanks a bunch!
    Jeremiah
  2. #2 Re: Timing Chain GASKET replacement
    follow the timing chain how to's you found, just dont change the chain.
    all you need is some rtv, a new gasket, and coolant elbows.
    and a balancer puller with the right bolts. all that info is in the how to change a crank sensor thread.
  3. #3 Re: Timing Chain GASKET replacement
    I break stuff selliott's Avatar
    Kansas City
    I just did it twice lol its not to bad should only take a couple hours. If you need more help pm me and ill help ya.
  4. #4 Re: Timing Chain GASKET replacement
    Nov 2014
    Indianapolis
    Thank you! As I am going through the "How to's" there is a wealth of info here!
    Much appreciated!
    Jeremiah
  5. #5 Re: Timing Chain GASKET replacement
    Nov 2014
    Indianapolis
    Thank you Selliott! I'm going to give it a go and we will see what happens
  6. #6 Re: Timing Chain GASKET replacement
    Kansas City
    No problem thats what we're here for
  1. Timing Chain/Belt replacement? Tension-er replacement?
    By void33 in forum General Tech Discussion
    Last Post: 02-21-2014, 02:34 PM
  2. timing chain replacement
    By joeybtlr in forum Introductions/Noob Questions
    Last Post: 01-15-2013, 08:33 PM
  3. Timing Chain Replacement How To?
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2010, 09:25 PM
  4. Timing Chain Replacement
    By Traeger2591 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-07-2010, 12:11 PM
  5. timing chain replacement question
    Last Post: 05-27-2010, 08:53 PM
