Can the ignition coils from a Series 2 fit a Series 3?
Yup just stick with n/a ones because I believe the gtp ones are different
Ok. Cause I gots a 2008 Buick Allure I am going to start to modify with a 3800 n/a. Thanks
Yes, the block is same. Will have to swap stuff. Definitely have to swap intake.
How did you lock it up? Sure you didn't lose intake gaskets or upper intake? Very common and hydro locks the motor.
Yes you can run LIM but its aluminum and you need adapter for the throttle body. I believe you have to do something for PCV. .
