Thread: Ssm90 swaps?
Results 1 to 8 of 8
  1. #1 Ssm90 swaps?
    Oct 2014
    St.Johns NL
    I've been trying to find out how everyone's fuel system is set up and how they have there vaccum lines ran, I just bought an adjustable pressure regulator and stainless lines for my swap . But with the hard plastic fuel lines coming from the car seem like they will kink if I move them. Leaving me with not many options for mounting my regulator. And I'm also seeing - in my boost guage at idle. -8 or so bar. Should that be like that? I have my map and fuel regulator lines hooked to the nipple under the snout . Along with the gauge!
    Also when I touch the throttle it bogs a bit before it will rev!
    So I'm asking. Post your swaps! So I can get some ideas going . And I have searched and searched !
  2. #2 Re: Ssm90 swaps?
    your best to just run all new soft vac line. cost ya like 5 -6 bucks.
    and that sounds right too as far as how its hooked up.
  3. #3 Re: Ssm90 swaps?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Sounds like you ran your vacuum lines correctly. Might need some tuning to fix this as it sounds like it is an AE tuning issue, also called Tip in fueling in some other ecu's.
    04 GTP -HAI, 1.9 rockers.
  4. #4 Re: Ssm90 swaps?
    Oct 2014
    St.Johns NL
    Should I be seeing the boost gauge in the negative though, at idle?
  5. #5 Re: Ssm90 swaps?
    Mercer, Pa
    No boost at idle, only vacuum. You see boost only in drive and only under load. The computer keeps you out of boost with the solenoid until you need it.
  6. #6 Re: Ssm90 swaps?
    Aug 2013
    Sandy, UT
    His solenoid likely isn't hooked up as its a swap from an NA car, How do you have the vacuum lines routed off the BBV?
  7. #7 Re: Ssm90 swaps?
    Oct 2014
    St.Johns NL
    I just have the top nipple on the BBV hooked to the tree on the top of the charger itself and have the lower vented to atmosphere!
  8. #8 Re: Ssm90 swaps?
    Aug 2013
    Sandy, UT
    Thats exactly how it should be.
  1. Engine Swaps
    By Kolton Lock in forum General Grand Prix Discussion
    Last Post: 11-03-2012, 07:27 PM
  2. engine swaps.
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 01-17-2012, 01:37 PM
  3. let's talk custom roots blower swaps
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2011, 10:15 AM
  4. 3800 series II Vin 1 - Pulley swaps
    By sledneck907 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2008, 01:08 PM
  5. Let me see your GEN V swaps
    By Blown97 in forum Visual/Body Modifications
    Last Post: 04-28-2008, 09:53 PM
