Thread: how much should my throttle plate open when applying gas?
Results 1 to 9 of 9
  1. #1 how much should my throttle plate open when applying gas?
    Dec 2013
    Niagara Falls Ontario
    Hi there, today i finally got around to trying to clean my throttle body and because its an electronic throttle body I was told at the store to run the car with the throttle body open and get someone to press the gas while I clean it, and not to mess with the throttle plate/butterfly valve because it would put the idle speed out of sync. The first thing I noticed was that the butterfly valve was barely opening when the gas was being pressed. Is that because the car was in park, or because I had the mass air flow sensor disconnected, or maybe because the throttle body needs to be replaced. and if the throttle body does need to be replaced, what are the steps involved in doing so, so that the the ecm will be in sync when all is said and done. Thanks in advance for any help.
  2. #2 Re: how much should my throttle plate open when applying gas?
    GrandPrix Junkie
    St. Louis
    Not sure how far they open on the DBW cars. Usually just remove the entire TB and clean it till it shines. Reinstall and away you go. The backside of the blade gets carboned up. Common issue.
  3. #3 Re: how much should my throttle plate open when applying gas?
    Dec 2013
    with a mechanically operated throttle body I know thats how they work, but with drive by wire I've read online and have been told that the ECM and throttle plate wont be in sync or work properly if you mess the blade/plate. I've also been told that cars with DBW have some kind of re learn state you can put them into if you do mess with the blade so the ECM can get back into sync. does any one know how to get the car in this state? by the way I guess I forgot to mention the exact car. Its a 2006 pontiac grand prix base mode 3800 series 3 engine.
  4. #4 Re: how much should my throttle plate open when applying gas?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    I don't know, both DBW TB I cleaned, I removed, held the blade open with my fingers, cleaned, re-installed. No issues on both cars.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  5. #5 Re: how much should my throttle plate open when applying gas?
    Dec 2013
    Did you do this on your 2004? and if so do you know if the 2004 GTP is the same as the 2006 base model? Thanks
  6. #6 Re: how much should my throttle plate open when applying gas?
    Quote Originally Posted by Greg84 View Post
    Yup
    04 Comp G.
  7. #7 Re: how much should my throttle plate open when applying gas?
    Québec
    Yep, did it on my '04 and my buddy's '06.
  8. #8 Re: how much should my throttle plate open when applying gas?
    SWPA
    Take it off, hold the plate open and clean it. The people at the store are misinformed. I have taken my TB off and held the plate open to clean it several times.
  9. #9 Re: how much should my throttle plate open when applying gas?
    Dec 2013
    Cleaned it today. Not sure if it helped yet. Got to wait until it gets cold to see if i still have trouble starting the car.
  1. tranny issue while applying wide open throttle
    By getrdunn69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-16-2013, 06:40 AM
  2. Gen V throttle body plate...
    By Juskenny7 in forum For Sale - Parts
    Last Post: 07-10-2013, 02:40 PM
  3. Throttle got stuck wide open
    By SilvaMan61 in forum General Tech Discussion
    Last Post: 02-28-2013, 04:01 PM
  4. wide open throttle technique
    By asite57 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2012, 05:00 PM
