Thread: Misfire
Results 1 to 7 of 7
  1. #1 Misfire
    Jan 2013
    Kansas
    About a week ago I did a tune up cause i was getting random misfire every now and then. Right after the tune up Cylinder #4 was misfiring like crazy, swapped the spark plug with #2; still number 4. Replaced old wire, and still number 4. So I put the new wire back on because i didnt have the time to mess with it and i had places to go. Later that day i noticed my engine was running fine, so i figured it had some carbon build up or something and finally got rid of it. This last weekend i went on a long road trip and it was running fine until i took a rest stop and shut it off. When i restarted it it, i could feel it had a misfire. When i got on the interstate and gave it gas it was misfire like crazy. It threw a code and i had my code reader with so I quicky read the code and it was random misfire. It was very noticable, then a few hours later took another rest stop and then it worked fine again.
    So you guys have any ideas?
  2. #2 Re: Misfire
    What brand of spark plugs?
    And have you tried switching a coil pack around to see if the misfire moves cylinders??
    Also the ICM under the coil packs could be faulty.
  3. #3 Re: Misfire
    Jan 2013
    Kansas
    AC Delco iridium
  4. #4 Re: Misfire
    Jan 2013
    Kansas
    No i havent, cuz after number four cleared up its just been random misfire so no specific cylinder. how would one check the ICM?
  5. #5 Re: Misfire
    Some parts store have ICM testing machines, but it can test good and still be bad as the problem isnt there 100% of the time.
    If you could or knew anyone else with a 3800, it's easier to swap ICM between cars and go drive it and see if the problem continues.
  6. #6 Re: Misfire
    Jan 2013
    Kansas
    Well sometimes it works perfectly so it would probably be during that time that it would work perfectly. I know alot of people with a 3800 but none are my good friends. if all else fails i may just buy new coil packs and icm.
  7. #7 Re: Misfire
    cheaper to grab one from a junk yard.
  1. Misfire?
    By blackflag in forum General Tech Discussion
    Last Post: 03-14-2012, 09:41 AM
  2. 04 GTP misfire?
    By Toms04compg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2012, 12:30 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. Help!!! Misfire
    By Kevin40th in forum General Tech Discussion
    Last Post: 01-30-2010, 09:20 PM
  5. 99 GT Misfire on cyl 6.
    By mazzafamily in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-28-2009, 10:12 AM
