Thread: Are they the same or ..??
Results 1 to 10 of 10
  1. #1 Are they the same or ..??
    SE Level Member KingOfTheSouth's Avatar
    Nov 2008
    homestead
    Is a 2008 gp se computer the same as a 2004 gp se.. Can they use the same performance chips..??
  2. #2 Re: Are they the same or ..??
    TDCRacing
    Guest
    Some cars use BCM communications, some don't. Wiring to the PCM may be different between years and different options I really don't know wich does and wich does not. It's never a good idea to put a PCM in your car that doesn't belong.
    And Any ''chips'' that you will find will be a compleate wast of you're time and money and do nothing for you're car.
    If you're looking for performance go with a tuned PCM
  3. #3 Re: Are they the same or ..??
    Banned
    Wichita Falls, Texas
    GM has done so much changing around with the new body style (04+) that I'm not sure. More than likely it is the same, but I'm not 100% sure. All I know is with the older body style any PCM from 98-02 will work in any 98-02.
  4. #4 Re: Are they the same or ..??
    Nov 2008
    Searcy,Arkansas
    I have a 07 and they do not make a tune for it. But I have been told and read where people have been putting the 05 into the 07 and its working. The only problem is the fuel reads wrong. But it was the supercharged ones not the SE.
  5. #5 Re: Are they the same or ..??
    Nov 2008
    homestead
    well the chip i was looking at was on summit and jet makes them for the computers. i was thiking of just taking it to a speed shop and letting them deal with it
  6. #6 Re: Are they the same or ..??
    Nov 2008
    homestead
    i really wanna get rid of that rev limiter my car gives out at about 110
  7. #7 Re: Are they the same or ..??
    it takes forever to get to 110 in a stock grand prix. how are you worried about going faster at this point?
  8. #8 Re: Are they the same or ..??
    TDCRacing
    Guest
    Just stay away from anything you have to add to you're car. The only thing bennefictial to these cars are to tune the pcm electronicly.
  9. #9 Re: Are they the same or ..??
    Nov 2008
    homestead
    actually my car gets up there pretty fast im not saying its a nascar but it makes it happen
  10. #10 Re: Are they the same or ..??
    Nov 2008
    homestead
    Quote Originally Posted by TDCRacing View Post
    Thanks i will look into that
