Thread: Just so you know....
Results 1 to 20 of 27
  1. #1 Just so you know....
    Banned - Busted For Scamming
    Feb 2009
    I will be swapping in a getrag 282 into my car, tired of the damn automatic and the bull shyte that goes along with it, its acting up again and im tired of it. I know alot of you are going to tell me that the tranny cant handle the power, but i will find out once and for all i guess. There has been alot of speculation on this subject, none actually confirmed to my knowledge that it wont hold up. There are many running in fieros, and i know while they may be lighter, not by much and with the weight savings going to the manual, its only around a 500 pound difference between the two cars. There are people running 400 hp plus v8's hooking up and holding no problem. I will be smart about launching, i will ease the shifts. No reason to bang gears every day anyways, and to dump the clutch. Also i might add that even if you think it wont hold up to the torque, its more then likely gonna bust the tires loose first, and im not going to be running slicks. Expect a writeup relatively soon, i will first get all the parts together, then dive into it. Just so you know...
  2. #2 Re: Just so you know....
    SE Level Member mickey t's Avatar
    Dover, DE
    I think you might have something good going... Let us know how it works out for you...
    The Surgeon General never said anything about smoking the competition
  3. #3 Re: Just so you know....
    have fun blowing that up too. those are more expensive to replace.
  4. #4 Re: Just so you know....
    Feb 2009
    bio i appreciate your input. i have to ask this question though, have you or have you known anybody that has run this setup before?
  5. #5 Re: Just so you know....
    Feb 2009
    and just so you know... its been done here.
    http://www.cardomain.com/ride/2458244/2
  6. #6 Re: Just so you know....
    Not saying it isn't possible...it is, no doubt...I'd rather get a build auto and be done...and it is faster too with a built auto trans.
    Yeah that is Miko's crazy sh*t Cutty...twincharged the whole bit...but he does EVERYTHING custom and is awesome at it.
  7. #7 Re: Just so you know....
    Feb 2009
    manuals are more fun IMO
  8. #8 Re: Just so you know....
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    More fun, but less consistent.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  9. #9 Re: Just so you know....
    Feb 2009
    depends on the driver
  10. #10 Re: Just so you know....
    Waynesboro, PA
    False.
  11. #11 Re: Just so you know....
    Feb 2009
    ok.... its going to be my fun DD so i dont really care about it being 100 percent perfect on the timing shifts. I want to have a fun l67 5 speed.
  12. #12 Re: Just so you know....
    SS Cobalt is cheaper in the long run I'd bet.
  13. #13 Re: Just so you know....
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    its not all about "consistency" the higher gear ratios of a 5 speed will allow you get up to your peak horsepower (around 6000 rpms) alot faster.
    when i raced my 5 speed cavalier agaisnt the same exact car, only an automatic, i was winning before i even shifted once, thanks to the higher gear ratio
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  14. #14 Re: Just so you know....
    Waynesboro, PA
    Quote Originally Posted by Jakegday View Post
    Then just upgrade your differential gears.
  15. #15 Re: Just so you know....
    it can be done, but i wouldnt want it in this car. way too heavy. a fiero? sure.
  16. #16 Re: Just so you know....
    Feb 2009
    the car isnt THAT heavy
  17. #17 Re: Just so you know....
    Jan 1970
    Maquoketa, Iowa
    Are the axles going to be the same or are you going with custom? I'd be worried about them for a DD manual. Njbrain on here did a manual swap too, he has a list of parts needed for the tranny he went with and a lot of pics.
  18. #18 Re: Just so you know....
    Feb 2009
    yea, i saw his thread, he used the opal f40 tranny though, im using the getrag 282, its easier to find, and people have used them in the fieros, while only being 500 pounds lighter, they have also put high hp v8s behind them no problem. As far as the axles, im not sure, will have to find out more then likely. Ive already found out about the clutch and flywheel, and probably need a oil filter relocation kit. gonna try to get the adapter the police impalas came with, they came with the factory oil cooler.
  19. #19 Re: Just so you know....
    Bastard Reptile's Avatar
    Kansas City, MO
    I don't know where you're getting your power info, but these engines peak way before 6000 rpm.
  20. #20 Re: Just so you know....
    Feb 2009
    idk all i know is its gonna be fun lol
