Hello all, I have a 2006 Grand prix with the 3.8 engine. The transmission broke a band so I replaced the transmission. The car ran fine for a little bit, but now I get "reduced engine power" displayed and the car runs extremely rough. Sometimes it ill stall. I pulled codes and everything pointed to either the throttle body or throttle pedal assembly. I replaced both and still have the same problem. I was looking around the engine bay to see if I messed something up and found a wire not connected but can't figure out where it goes. The wire runs along the top of the transmission and is clipped to the shift cable bracket. Do any of you know where it connects to? Thanks
