Thread: cooking parts
Results 1 to 11 of 11
  1. #1 cooking parts
    Feb 2010
    TN
    Can water pump and a tensioner take being put in s 400 oven twice for 30 minutes at a time without damage?
    I know some of you are scratching your head why i asked this and. That's the fun part lol
  2. #2 Re: cooking parts
    It should be fine.. Guessing your powdercoating them. Obviously remove as much as you can.
    04 Comp G.
  3. #3 Re: cooking parts
    powder coating are ya?
    the tensioner would make it ok. but take the water out lets off the end for the heater hoses they have a o ring inside that will likely fail. id take the pulley off, unless your coating it too.
    the water pump? i dont know really if it will make it. only one way to find out right?
  4. #4 Re: cooking parts
    Feb 2010
    TN
    Wondering about the grease in the pump bearing melting away
  5. #5 Re: cooking parts
    its a sealed unit so the grease will just take a real good heating. if it leaks grease the seals failed.
    maybe just paint the water pump?
  6. #6 Re: cooking parts
    Feb 2010
    TN
    That's what I'm thinking paint it hey Am I going to need a new gasket for the tensioner
  7. #7 Re: cooking parts
    you need new coolant elbows, good time to upgrade to the new metal ones.
  8. #8 Re: cooking parts
    SE Level Member Pontiacmaster81's Avatar
    Jan 2014
    New York
    Oh yes those Plastic ones are garbage I just found out the hard way and placed the Aluminum ones in
    2002 PONTIAC GRAND PRIX GT
    "LISTEN! CAN YOU TELL THE DIFFERENCE BETWEEN
    A CAR WITH A BAD TRANSMISSION, AND ONE THAT IS POSSESSED BY A DEMON FROM HELL?"
  9. #9 Re: cooking parts
    Quote Originally Posted by Pontiacmaster81 View Post
    Right..cause I've run those plastic crapboxes for over 200K w/o issue. BTW.. enjoy the issue when the same damn oring from the plastic one let's go on your aluminum and it's fused itself into the area with corrosion.
  10. #10 Re: cooking parts
    Feb 2010
    TN
    Oh yeah I bought the metal ones right off the bat
  11. #11 Re: cooking parts
    Feb 2010
    TN
    I can't complain those are the originals and they have 328,000 on them I been lucky
  1. Replies: 29
    Last Post: 09-03-2014, 09:42 PM
  2. New hot dog cooking method??
    By Mad Monkey in forum Off Topic Discussion
    Last Post: 07-09-2012, 06:25 PM
  3. Cooking Subwoofers
    By 2007GrandPrixGT in forum Audio, Security & Visual Electronics
    Last Post: 05-29-2012, 10:31 PM
