Thread: Car heat-seized
Page 1 of 3 123 LastLast
Results 1 to 20 of 57
  1. #1 Car heat-seized
    Jun 2012
    Ontario Canada
    Hello fellow GP enthusiasts
    I was driving home the other day and my rad hose popped off the top of the radiator, pissed coolant everywhere, I didn't notice until my car started making a ticking noise and shut off completely about 1/2 KM later.
    I opened the hood to billowing white smoke and the smell of burning coolant, after realizing what happend I had an "oh ****" moment
    So, what I have done:
    Change oil right away
    new coolant
    replace rad hose and clamp
    replace #6 and #3 spark plugs (Were throwing a mis-fire code)
    Before I replaced those spark plugs the engine was shaking really violently at idle but smoothed out with any throttle. It has since smoothed out to a reasonable level and isn't throwing any misfire codes (yet) and I was wondering if there is anything else I should check?
    Thanks,
    Donny
  2. #2 Re: Car heat-seized
    So it's still running funny or what are you asking now?
    You might need new wires if it still runs sorta rough, that would be a cheaper solution and clean and check the coil packs.
  3. #3 Re: Car heat-seized
    Jun 2012
    Ontario Canada
    It seems to be idling funny still yeah, it's smoother that I changed the plugs but doens't seem to be back to 100%
  4. #4 Re: Car heat-seized
    Jun 2012
    Ontario Canada
    Quote Originally Posted by xDonny View Post
    Well just drove a couple miles to pickup my sister at work and seems rough again... Just realized 3 and 6 share a coil pack so that's what I'm gonna check when I get home
  5. #5 Re: Car heat-seized
    Jun 2012
    Ontario Canada
    Another update:
    Wasn't the plugs, wires or coil packs.. Thinking of renting a compression tester to see if it's a chipped piston or something, the plug wasn't mangled so I'm hesitant about that.
    I was also thinking it could be a rocker or a bent rod?
    Any thoughts on the matter gurus?
  6. #6 Re: Car heat-seized
    Jun 2012
    Ontario Canada
    Update again:
    Unplugged #6 injector... no change
    Replacing will update
  7. #7 Re: Car heat-seized
    Jun 2012
    Ontario Canada
    Replaced injector.. no change
  8. #8 Re: Car heat-seized
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    The PO could have chipped it and replaced the damaged plug. If you can get a borescope to check that would be good
    Edit: saw your gonna do a compression test.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  9. #9 Re: Car heat-seized
    Compression test, inspection camera time !
    04 Comp G.
  10. #10 Re: Car heat-seized
    Aug 2013
    arlington, tx
    Are you having a high rpm at idle?
  11. #11 Re: Car heat-seized
    Let's level set here. NA usually doesn't chip a piston Overheating badly can crack a head/kill a head gasket. Still..it does take a lot.
    Saying it's running bad is tough to diagnose. Could you post a video?
  12. #12 Re: Car heat-seized
    Jun 2012
    Ontario Canada
    I sure can, when I scan it it always says misfire on 6 cylender... Video coming soon
  13. #13 Re: Car heat-seized
    Jun 2012
    Ontario Canada
    It does idle a little higher (around 1050). I'm uploading the video now.. 34 mins to go
  14. #14 Re: Car heat-seized
    Apr 2012
    Dayton, OH
    Had no idea it was N/A he never specified.
    2012 F150 STX
  15. #15 Re: Car heat-seized
    Mar 2012
    NC
    Did the coil packs get covered in coolant? Might've fried the ICM...
  16. #16 Re: Car heat-seized
    I also...have overlooked which section it is in many many times. It's mainly because I read all new posts all the time. Totally understand, when he didn't specify either.. I don't assume either.
  17. #17 Re: Car heat-seized
    Jun 2012
    Ontario Canada
    https://www.youtube.com/watch?v=ceQq...ature=youtu.be
    video
    You can't really tell because of the video stabilization but the engine shakes quite a bit more than the video let's on
  18. #18 Re: Car heat-seized
    Aug 2013
    arlington, tx
    Im thinking a bad head gasket. Sounds almost like mine when mine went out. Go get a block tester from autozone and test to see if you are getting exhaust fumes through your radiator. If the liquid turns a different color, it means you are.
  19. #19 Re: Car heat-seized
    Aug 2013
    arlington, tx
    And check your oil too to see if it looks like chocolate milky
  20. #20 Re: Car heat-seized
    video
    how about we fix that vac leak too. all the hissing is a vac leak. car at idle spray some carb cleaner at the lines, when the idle jumps up you found the leak area.
  1. Rotors Seized on Used m90
    By hdnseek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2013, 02:27 PM
  2. Turbo seized this weekend
    By ls1camino in forum Turbo
    Last Post: 05-22-2012, 08:57 PM
  3. Motor seized.
    By WOTFTW in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2012, 02:48 PM
  4. Engine seized?
    By seanparker3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2011, 12:52 AM
  5. Engine Seized
    By Green38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-09-2010, 01:33 AM
