car-part.com
Why would you change a rear main?
Not main, the manifold
Rear exhaust manifold.. ohhhhhh yes, now your post (only that one) makes sense.
You know that was pretty funny. So if you get an 04 with 140K, swap the LIM gaskets as they'll be plastic, regasket the oil pan and change the rear engine cover gasket (not valve cover) behind the flex.
Im going to try to get a lower milage one today
Just ordered an l26 with 108k
It doesnt seem to bad no worries.
350 bucks
Cant remember if i was this bad when i was his age...
Probably should stick with the new motor and current mods and leave it be. I got the same mods but im plottin on a turbo by the summer. Good luck homie
L26 with aluminum upper is a good base for a turbo build
