Expect to spend 700-1000 on just parts.
Thought I need new springs and retainers. And seats
Seriously?
Before you do anything else to your car I suggest you do a lot more reading.
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ please.
Theirs nothing on here about these cams. Reason I posted this
who is going to install this for you?? :th_eyesrolling:
The information is out there you just need to learn to internet better.
As the guy that helped you fix the diff and in a sense kill the engine...i'll weigh in.
1. Have your "connection" source you a low mileage motor from an 04-08 GP, or Lucerne etc. Locally I'm paying $300 for low mileage NA motors.
2. Swap the rear exhaust manifold with yours, get a TB adapter from Gen V to L67.
3. Buy an L67 TB and get your pcm programmed for the change in maf tables
4. Drop on that Plog and DP
5. Put in the HV3
6. GT1 cam actually does a pretty nice job in an NA, it's not worth it IMO. Cost vs power isn't right.
7. Realize I know what I'm talking about.. I'm driving an NA Regal GS (that's the SC'd model) with 2.93 (stock SC tall gears). It's faster than most think it should be. Only mods.... Plog, DP and L67 TB.
How do I swap to a series 3? And can I use my stock throttle body till im able to get it tuned
But I already have a brand new uim and the hv3 for it.
Read bills post, you would need an l67 TB and a TB adapter. If you go series 3.
Sent from my Galaxy Tab 3 8.0
Ide like to stay series 2 because ive got a new uim and hv3
You could use the SIII block. Just swap on the SII LIM and UIM that you have.
Just the swap thats it
Yes sir. Then you can bolt up the throttle body without an adapter.
If you pulled the UIM off the L26 (S3) you can bolt the L36 one to it. I like the L26 UIM because I had an adapter and L67 TB.
L26 can be had for a lot less than a l36, and 9 times out of 10 they have less miles.
Sent from A Galaxy Far Far Away........
Whys a l26 cheaper than a l36 shouldnt it be opposite
