Thread: 200,000 mile tune-up
Results 1 to 6 of 6
  1. #1 200,000 mile tune-up
    Feb 2010
    Warren, Mi
    My 2000 GP GT just turned over 200k miles. I am planning a complete tune-up. What else do you guys recommend outside the plugs, wires, fuel, air and oil filter?
    Thanks
  2. #2 Re: 200,000 mile tune-up
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Trans Fluid and filter replace, maybe thrown it a transgo shift kit while you got the pan off.
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: 200,000 mile tune-up
    depending on the trannys fluid condition, a pan drop and filter change.
    belts, rad hose's, check all the pulleys. coolant flush, change to green if your still running that dex crap.
    and as always change the lim gaskets if its not been done, use the upgraded metal gaskets. seal the 2 coolant ports in the lim so the upper can never fail on you. if you do the lim, you need new coolant elbows, they sell metal ones now, get those. and a hand full of vac lines to fix the ones that will break during the lim job.
  4. #4 Re: 200,000 mile tune-up
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    That ^^ If needed of course. If transmission fluid is good leave it alone. Sometimes messing with them at that high of a mileage can mess them up sooner.
    If You Cant Hear The Whine You're Too Far Behind...
  5. #5 Re: 200,000 mile tune-up
    Jun 2012
    south haven mi
    valve cover gaskets if they haven't been done
  6. #6 Re: 200,000 mile tune-up
    Nov 2011
    NY
    As mentioned... All fluids, filters, wearable items, wires, etc., but in case these weren't mentioned...
    Give the entire fuel line a clean out with seafoam before replacing filter, lol. You can rebuild injectors too if adventurous, there's a write up here. T-Stat wasn't mentioned as well as replacing Dex-Crap with anything else. When checking gnoton stuff, wires lugs, give the coils a once over. Bleed brakes, check lines, new alignment and rubber if needed. Tranny, well, yeah, if never touched, then don't. If maintained, then pan drop, new filter at min., then suspension too, check all bushings, ball joints, sway, control arms, etc. at 200k, the ride is definitely going to need some tlc. When all that's done, take it and get it detailed or do it yourself. Q-tip treatment : ) dont forget headlights, tails and any lamps needing replacement. Then weatherstripping too is worth a check over... As well as exhaust system. Generally, a good once over the entire car and you'll get many a more miles...
  1. Low Mile GXP
    By cru ss n in forum For Sale - Vehicles
    Last Post: 04-13-2013, 12:35 PM
  2. 2005 Grand Prix GT 100,000 mile tune up
    By mrockteacher in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2011, 10:19 AM
  3. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  4. Tune and 1st 1/8 Mile Run
    By jshifti33 in forum Off Topic Discussion
    Last Post: 07-16-2010, 08:36 PM
  5. What do you think I will run in the 1/4 mile?
    By jmj4492 in forum Off Topic Discussion
    Last Post: 04-22-2010, 05:43 PM
