Thread: loud Engine Whine follows Rpm ( a/c compressor bearing)
Results 1 to 5 of 5
  1. #1 loud Engine Whine follows Rpm ( a/c compressor bearing)
    Jan 2014
    CT
    This is my first post as a member here but have used this great source of info threw out the years.. I have a very loud whine which follows RPM Its so hard to tell were its coming from but I am thinking a/c compressor bearing anyone change one while still in car what's involved any help would be appreciated..
  2. #2 Re: loud Engine Whine follows Rpm ( a/c compressor bearing)
    Easy to change. When it get warmer out see if it goes away if you kick the compressor on
  3. #3 Re: loud Engine Whine follows Rpm ( a/c compressor bearing)
    Jan 2014
    CT
    The noise has been going on since summer. How goes the clutch get removed and is the bearing pressed in
  4. #4 Re: loud Engine Whine follows Rpm ( a/c compressor bearing)
    take the belt off, spin all the pulleys by hand. the one that dont spin freely is the problem.
    a/c clutch's are best not changed. ( you need special tools) buy a new a/c compressor you best option by far.
    if it is the clutch, sometimes you can spray some lube into it and it will quiet down.
    if the sound goes away when the a/c is on, its the a/c clutch for sure.
  5. #5 Re: loud Engine Whine follows Rpm ( a/c compressor bearing)
    St. Louis
    Have you checked your power steering and trans fluid level? Both of those can whine and be RPM dependant as well.
  1. Loud whine in engine bay
    By OZZY1123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2014, 06:30 AM
  2. Loud whine, Can't go over ~75 and shifting issues
    By Explicit_Spade in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2011, 05:58 PM
  3. Loud obnoxious whine from supercharger
    By TheBeastGTP in forum General Tech Discussion
    Last Post: 03-27-2011, 10:45 AM
  4. loud whine when driving
    By joshsGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-10-2010, 09:11 PM
  5. loud whine???
    By ionroller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2009, 06:18 AM
