Thread: Engine knock...any ideas?
Results 1 to 20 of 26
  1. #1 Engine knock...any ideas?
    Canada
    Hi guys, it's been awhile since my last post. I recently noticed a knocking sound from my engine although it needs to be warmed up before u can hear it(as when it's first started up its fine...usually takes about 3-5 mins before knocking sound starts)
    Some notes to consider ...maybe?
    I changed oil to synthectic about 3000-4000 kms ago.
    The "knocking" sound is only at idle (the sound goes away as soon as I press the gas pedal)
    Any ideas?.......At first i thought it may have a stuck valve, but I wouldn't think it would take the 3-5 mins to start hearing that as You can usually hear them right off on a cold startup.
    Thx for any ideas.
  2. #2 Re: Engine knock...any ideas?
    Got a video?
    The low oil pressure dummy light isnt flashing is it?
  3. #3 Re: Engine knock...any ideas?
    Canada
    No the oil light isn't on...and sorry no video.
    Also changed the oil back to normal 5w30...not synthetic just today...funny thing I had the front of the car jacked up until the tires were 5 inches or so off the ground and let the car run for 5 mins and no knocking sound. However after changing the oil and driving the 15 mins back to my house the knocking is there again..... only @ idle thou( like always).
    I would assume if it was a internal engine problem it wouldn't take time to start knocking as it always does.
    Also it is not burning any oil ..It's got me stumped!
  4. #4 Re: Engine knock...any ideas?
    flex plate broke maybe. need a vid or sound clip at least.
  5. #5 Re: Engine knock...any ideas?
    Sep 2011
    MI
    not sure what kind of mileage the car has, but you should never switch to synthetic on hi mileage cars.
  6. #6 Re: Engine knock...any ideas?
    Canada
    I'll have to get a vid of it although not sure how to upload it so ppl could view it.....the car has 145k on it ..I was told that as well that is why I went back to normal oil.
  7. #7 Re: Engine knock...any ideas?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    You can upload it to youtube and post the link here. I think photobucket lets you upload videos also.
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: Engine knock...any ideas?
    Canada
    Thx I will try and get a video of it tomorrow and upload it ...thx for replies btw.
  9. #9 Re: Engine knock...any ideas?
    Take the plastic guard off the flex plate cover and see if you can find a crack in the flex plate itself. You will have to bump the starter or turn the motor over by hand to see the whole thing.
  10. #10 Re: Engine knock...any ideas?
    Canada
    I'll have a look tomorrow as well....Are you talking the flywheel?
  11. #11 Engine knock...any ideas?
    Flexplate
    04 Comp G.
  12. #12 Re: Engine knock...any ideas?
    Canada
    If it were the flexplate would I not have a problem when engaging the starter to start the car...or is this not often the case?
  13. #13 Re: Engine knock...any ideas?
    starter works fine, it cracks then clunks. stops with some gas. engine needs to come out, or the tranny, pick one. if its the flex plate.
  14. #14 Re: Engine knock...any ideas?
    Not always the case if you had teeth missing then yea it'll prevent the start from engaging but a flexplate crack will still allow the car to run it'll just make noise
    04 Comp G.
  15. #15 Re: Engine knock...any ideas?
    Canada
    Oh Goodie lol! I'll have a look...thx guys.
  16. #16 Re: Engine knock...any ideas?
    Pennsylvania, USA
    You can switch to synthetic whenever you want, please don't believe those old myths. The only thing synthetic may do is leak more.
  17. #17 Re: Engine knock...any ideas?
    HUDSON
    Another thing to check would be sludge build up in the bottom of the oil pan. Sludge can block the oil from being sucked up the the oil pump when the engine is running. I worked on a dodge that the problem was low oil pressure after 5 min. of running time, turned out the be sludge in the oil pan, 1 inch thick.
  18. #18 Re: Engine knock...any ideas?
    Canada
    Sorry guys been very busy but now have link to video.......sound starts @ 2:06 and gets worse...I give the engine a small rev @3:45-46 and again @ 3:59.....any ideas are greatly appreciated
    https://www.youtube.com/watch?v=V9Zu...ature=youtu.be
  19. #19 Re: Engine knock...any ideas?
    Rod knock start searching for a used engine
    04 Comp G.
  20. #20 Re: Engine knock...any ideas?
    if your lucky its the flex plate.
    make another vid, but hold it at say 2,000 rpm's for a few seconds, then let the throttle snap back to idle.
    also move the camera around the engine so we can hear it from all sides. and under the car.
  1. help have engine knock.
    By twentyocho in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2013, 10:24 AM
  2. Engine Knock
    By chrisangelly1981 in forum Introductions/Noob Questions
    Last Post: 01-23-2013, 01:42 AM
  3. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  4. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
